Old 02-28-2009, 05:27 PM   #1
MotoTek
Always Under Construction
MotoTek's Avatar
Transmission Tunnel Heat Wrap
What are you guys using for heat wrap in your transmission tunnel, or what do you suggest? I want to crack down on diverting all heat away from the interior as I've removed my A/C finally. The engine and transmission are out of the car right now, so this is a better time than any. All sources I've searched for point towards Thermotec. Is there anything else out there anyone recommends? Some sort of spray?
http://www.thermotec.com/cool-it-mat.html
http://www.clubrsx.com/cr/DEI-RAG.html
-mike
BLACKADDE™ | ADGT RX7 |
Old 03-06-2009, 04:29 PM   #2
afgmoto1978
afgmoto1978's Avatar
Gold Heat Shield
Pegasus Auto Racing Supplies
http://www.pegasusautoracing.com/gro...ID=HEATBARRIER
Old 05-12-2009, 11:00 AM   #3
albertomg
Originally Posted by afgmoto1978 View Post
Gold Heat Shield
Now that I look at this a bit closer, that gold stuff is only $3 more than the non-gold stuff. Its really not that much more expensive.
93 Vintage Red R1
Power: Street Ported Motor, 99 Twins, V-mount, DP>SMB cat/MP> RB cat back, PFC, 1300cc secondaries, Fuel Pump, ACT clutch, RB lwfw, etc
Steve Kan tuned - 310rwhp at 10PSI
Suspension: Tripoint custom valved Koni + Ground Control coilovers, Eibach sway bars, SuperPro bushings, Corner Balanced and accurately aligned
Brakes: RacingBrake 4 corner BBK
SSR Integrale 17"x9" +45, Dunlop Star Specs 255/40
Old 03-09-2009, 09:01 PM   #4
albertomg
-mike
I have been using either the Thermotec or DEI stuff. I haven't even done it from the exterior yet. I just placed a layer over the tranny hump from the inside under the carpet. Even that made a big difference in my car. No need go broke on the gold stuff IMO.
Old 03-11-2009, 03:12 PM   #5
But the gold stuff looks so COOL!! Literally
Some day, I'll do that gold stuff to my FD... some day..
Old 03-11-2009, 03:03 PM   #6
afgmoto1978
Lol
Old 03-18-2009, 04:41 PM   #7
albertomg
Yes it does look very cool. I'm a "bang for the buck" kinda guy.
93 Vintage Red R1
Old 03-20-2009, 02:07 PM   #8
classicauto
crash auto?fix auto
classicauto's Avatar
Although to be honest, seeing pics of Adam's engine bay I thought that gold foil was a helluva lot more $ then what it is...
Old 03-26-2009, 12:47 PM   #9
War Eagle
War Eagle is on a distinguished road
Well it doesn't have the gold bling, but I did use DEI tunnel/heat shield for my FD:
http://www.designengineering.com/pro...sp?m=sp&pid=27
I called DEI and asked them what the best product would be to reduce exhaust temps inside the passenger side of my car. The recommended the heat shield product because it can withstand up to 1,750 degrees in temps and because the adhesive that holds it on is good up to 450 degrees.
So, I installed it on my car. Easy to do as you just trim it to your desired shape, peel off the plastic backing and then apply. As I have a Magnaflow muffler in my mid pipe, I was particularly concerned about this section so it was my area of concentration. Worked out great and my seat of the pants two hour drive says it does a nice job of controlling temps.
A few pics:
FYI, the undercoating material on the car is Quiet Coat (http://www.quietcoat.com/), the best product for eliminating noise from your car. It sprays on and reduces 2X the noise of Dynamat. It also weighs much much less.
War Eagle is offline   Reply With Quote
Old 05-12-2009, 11:04 AM   #10
albertomg
This is pretty attractive too since it includes a sound barrier.
Hmmm...
93 Vintage Red R1
Old 05-14-2009, 06:22 AM   #11
War Eagle
Hmmm...
Yes, and it works. I drove the car to DGRR last month. It's a 7.5 hour drive. The passenger side used to heat up nicely and you could definitely tell it was getting hotter over there than the driver's side. Not on this trip. The shield eliminated the heat issue completely. As for the sound barrier, my car is pretty quiet anyway as I have QuietCoat on the car (see above post) but my father-in-law and I both thought the noise was reduced even more.
Old 06-12-2009, 04:14 PM   #12
skidtron
skidtron is on a distinguished road
How much cleaning was required for the adhesive to stick to the chassis?
skidtron is offline   Reply With Quote
Old 06-12-2009, 07:02 PM   #13
War Eagle
None. We put it on "as-is" and it is holding fine. The adhesive is super sticky so I don't think you'll have a problem.
Old 06-13-2009, 12:54 PM   #14
RIZZXX7
DIGG7ER
RIZZXX7's Avatar
RIZZXX7 is on a distinguished road
how much was it?
EXCELLENCE IS NEVER AN ACCIDENT, IT IS ALWAYS THE RESULT OF HIGH INTENTION, SINCERE EFFORT, INTELLIGENT DIRECTION, SKILLFUL EXECUTION AND THE VISION TO SEE OBSTACLES AS OPPORTUNITY...
RIZZXX7 is offline   Reply With Quote
Old 06-13-2009, 02:08 PM   #15
War Eagle
About $80 shipped:
