Old 02-15-2009, 03:05 PM   #1
sumdeus
sumdeus's Avatar
sumdeus is on a distinguished road
Oil bolt problem?
Ok, so I pulled out of my garage today and to my horror I found this:
Quick survey of engine bay revealed nothing, but on the bottom of the oil pan I saw this;
I changed the oil about a month ago. And this is the first sign of an oil leak. I did get my tires changed on Friday at a local place, but they should have no reason to touch the oil bolt. The spray pattern seems to indicate that it may have happened while driving.
With the car jacked up I found the bolt was very loose, finger loose. So I tightened up with a wrench. It was a very slow leak, and so it never went dry, but I am just watching it now to check for any more leaking oil. Anyone ever have some mysterious oil pan bolt loosening?
sumdeus is offline   Reply With Quote
Old 02-15-2009, 05:30 PM   #2
there is a chance that it vibrated loose.
Old 02-15-2009, 06:12 PM   #3
Jeff20B
Jeff20B's Avatar
Sometimes people only finger-tighten the drain bolt. They tell themselves they'll remember to fully tighten it in a bit. Even a minor distraction can make you forget.
The bolt won't vibrate loose in my experience.
Old 02-16-2009, 09:37 AM   #4
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
Atkins Dan is on a distinguished road
This is why I leave the wrench on the floor so I wilt forget to tighten the bolt.. and even if I did that I end up checking it again just to be sure..
Dan
82 SuperCharged rx-7 {my toy not the daily driver anymore now under restoration}
88 B2200 rotary powered with a 7inch Camden SuperCharger !RIP! Jan/4/2007
2001 626 5-speed 80k on the clock all stock {Truck replacement}
2005 MAZDA6 V6 WAGON now that is a pimping ride all stock for the moment.. Paid off
WWW.AtkinsRotary.com
Atkins Dan is offline   Reply With Quote
Old 02-16-2009, 10:02 AM   #5
I did that when I changed my diff fluid on my 8..
Also, don't forget to change the crush rings once in awhile.. I had it on other cars before where it leaked because the washer was too worn out.
Old 02-16-2009, 10:10 AM   #6
My5ABaby
My5ABaby's Avatar
I've heard it's best to replace them every oil change. Granted nobody does, but I'd definitely do it in light of this issue.
Community Service Manual
RotorWiki
Old 02-16-2009, 10:43 AM   #7
Yeah, Thats what my toyota dealer told me 10 years ago and the parts guy used to just include them with the filter I bought from them. I now use the oil suction thingy to change oil. I haven't taken the drain plug off in over 4 years on my FD.
Old 02-16-2009, 10:47 AM   #8
My5ABaby
My5ABaby's Avatar
A what?
I was thinking of getting a quick oil drain valve. However, my money is better served elsewhere (i.e. food and rent) for now. http://www.quickoildrainvalve.com/
RotorWiki
Old 02-16-2009, 11:24 AM   #9
My5ABaby
My5ABaby's Avatar
Interesting. Looks like a good investment for my future plans.
RotorWiki
Old 02-17-2009, 10:59 AM   #10
bose
Member
bose is on a distinguished road
I haven't heard of a drain plug vibrating loose. As long as it never went dry .
I change my washer every time, dealer gives it to me with the filter.
bose is offline   Reply With Quote
