Old 01-24-2009, 01:42 AM   #1
TLDavid83
TLDavid83 is on a distinguished road
2004 RX-8 Starting/ Shifting problems
I just got an 04 RX-8, AT with 45k miles. I had it sent home to my brother as I am headed overseas for a year and am unable to take it. He called me today and said that while he was driving it it felt as though it wasn't putting out much power. Then he said the gear indicator on the dash would fluctuate from four to two on its own. When he came to a stop it completely cut out on him and now it wont turn over when he goes to start it. I didnt do too much research on RX-8s prior to buying this one. I've just wanted one forever(or since 2003). Anyway, I've been on several forums now and I see a consistant amount of people saying they have the same problem...specifically with the 2004 model. Is this really a known problem and if so, what is the common fix? By the way, I'm new to the RX-8 as well as rotary engines if you can't tell. Any info/ advice would be greatly appreciated.
TLDavid83 is offline   Reply With Quote
Old 01-24-2009, 09:55 AM   #2
lilring
Rotary Man
lilring's Avatar
lilring is on a distinguished road
well I can tell you that the shifting problem is normal. I thought something was wrong with mine but I took it to the dealership and the master tech sad it was normal. Now the shutting down is a problem but I dont know what that could be. Good luck with fixing the problem. and thank you for serving for our country
2005 Mazda RX-8 Velocity Red Mica - Daily Driver
2004 Mazda RX-8 Titanium Gray Metallic - RIP
1997 Mitshibishi Eclipse GST Black -Sold- RIP
lilring is offline   Reply With Quote
Old 01-24-2009, 12:55 PM   #3
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
Is this the first engine on this car? 04 Auto's are known for engine failures.....sorry for the bad news. Get a compression test done ASAP.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 02-17-2009, 02:14 PM   #4
Jedi54
Jedi Master
Jedi54's Avatar
Jedi54 is on a distinguished road
2004 Auto? Those were a bit problematic when they first came out. It could be a carbon build up issue which has lowered the compression which means the engine could be going.
FORTUNATELY the rotary engine is warrantied for 8 years / 100,000 MILES so have your brother call the dealership and tell them he has "severe lack of power" (those are the key words) and they'll get him in for diagnostic
Jedi54 is offline   Reply With Quote
