Old 12-09-2008, 03:02 PM   #1
Thoughts on 1 piece 2mm seals?
What is the advantage of using these over a 2 piece seal? Atkins seals them as a "race" seal so i am curious.
Old 12-10-2008, 06:22 AM   #2
-xlr8planet-
-xlr8planet-'s Avatar
if you go jport or big bridge, you cant use 2 piece seals, the triangular piece could fall into the intake port
Old 12-10-2008, 07:54 PM   #3
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
if you just do a half bridge you won't have to worry about that-
Old 12-10-2008, 08:13 PM   #4
TheDriver216
TheDriver216's Avatar
You have to clearance 1 piece seals a little more to give room for expansion which can also cause tough cold starting.
Old 12-10-2008, 08:14 PM   #5
-xlr8planet-
thats why I AM doing a half bridge
Old 12-10-2008, 08:29 PM   #6
12arotary
12arotary's Avatar
though from what I have read the power out put from a half bridge vs a large street port don't seem to be worth it with the wear on a bridge or half bridge being significantly more and reliability goes down, I'd say full or none
Old 12-10-2008, 03:40 PM   #7
classicauto
crash auto?fix auto
classicauto's Avatar
Never tried a 1 piece seal yet, but I know the 5+ failures I've had of OEM seals (and atkins.....) were breakages that occured at the very tip of the long portion of the seal, where it meets the corner piece. Given that alone, I'd say a 1 piece seal might take 2-3 more pings vs. a 2 pc. Of course, when it does fail, its probably going to take a lot more stuff with it too
Also, I know the dynamic compression of 1piece seals is not as high as 2piece given the sealing surface of the 2 piece can move around a little more and "fit" the housing/irons better.
Old 12-11-2008, 10:45 AM   #8
classicauto
crash auto?fix auto
Yes and no on that. I ran a 1/2 bridge for a while, still have the plates and may go back to it eventually. Its good, but there's not the FULL benefit there obviously. However it'll ABSOLUTELY spool the turbo faster and will net a slight power increase if only attributed to the harder hitting turbo response. Definetely worth while, although more gain can be had with a full bridge for sure.
Old 12-11-2008, 02:45 PM   #9
maybe ill just fiddle with 2mm 2pc seals then.
