Old 06-27-2008, 10:50 AM   #1
My5ABaby
My5ABaby's Avatar
Brake rotor choices... which one?
I'm going to be buying some new front brake rotors and I'm curious to see if anyone has experience with any of these brands (or if it matters). All of these are from Autozone, Advance, and O'Reilly.
My options are:
Beck Arnley: 31.99
Duralast: 28.99
Wearever: 28.98
Bendix: 79.48
Raybestos: 19.99
Wagner: 46.99
Brembo: 38.40
Community Service Manual
RotorWiki
Old 06-27-2008, 11:33 AM   #2
I work for Beck/Arnley. Therefore they are the best.
Seriously though, we don't deal in inferior parts. They have to all exceed the OE specs, not just meet the OE specs.
Old 06-27-2008, 12:01 PM   #3
My5ABaby
My5ABaby's Avatar
Sounds like a plan then.
RotorWiki
Old 06-27-2008, 12:40 PM   #4
JL1RX7
If you can find ten people to get cquence rotors they are not bad. I got the cross dimmpled and slotted for about 180 for all four shipped from cali to virginia. If not they about fifty bucks more. Had them for about six months and love them so far.
Old 06-27-2008, 01:22 PM   #5
Just get the brembo blanks or the BECKS (i've never heard of them but the guy above recommends them). OEM replacement and cheap.
Since we're on the topic of rotors:
Are tehre benefits to drilled and/or slotted rotors? I'm un der the impression that the holes help relieve heat and reduce brake fade but are there really reliability and cracking issues with them?? I've never had a problem but I'd like your input.
Old 06-27-2008, 01:36 PM   #6
In my opinion, they are not worth it for a street car. Yeah, they might look cool, and impress your friends, but not necessary for most. And I have had too many friends use them on a DD and get the cracking around the holes.
The stock rotors (mostly the calipers) do a fantastic job at bringing the car down from speed.
Old 06-27-2008, 03:13 PM   #7
TehMonkay
drilled/slotted crack when road racing, unless theyre very very whell made.
Napa sells blanks that are made in italy(i have some at home) i would try those or brembo.
Old 06-27-2008, 03:23 PM   #8
MaczPayne
Bah!
MaczPayne's Avatar
I have the cquence dimpled(not drilled!)/slotted rotors. We'll see how they do on July 13 at Buttonwillow
Johnson
TA FC in the works!
Old 06-27-2008, 04:15 PM   #9
I prefer slotted over drilled as drilled does seem to be more prone to cracking. Slotted gives better initial bite.
On the rally car we went with brembo blanks - higher than OE but no holes or slots to get dirt/grime caught up and cause delayed brake response!
I think like others have mentioned, for a street car a nice blank rotor from a superior company and good HPS pads from Hawk, and you're set.
Old 06-27-2008, 04:40 PM   #10
we have the drilled rotors and they held up fine at thunderhill but I still don't know if I should expect cracking or damage in the future.
Old 06-27-2008, 10:17 PM   #11
Just say no to cross drilled brake rotors.
Old 07-02-2008, 11:32 AM   #12
You need to break in any new brake rotors and / or brake pads.
Old 07-02-2008, 03:26 PM   #13
My5ABaby
My5ABaby's Avatar
I've heard of breaking in the pads (After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph), but I hadn't heard of one for rotors. Or is it the same thing?
In my case, I'll be putting on a new set of Hawk HPS' and new calipers along with the new rotors.
Edit: I found this: http://shielsmasonry.com/Beddingpadsandrotors.pdf . It would seem that I could break in the rotors and pads at the same doing what the I put in parentheses above (After installing new pads make 6 to 10 stops from approximately 35 mph with moderate pressure. Make an additional two to three hard stops from approximately 40 to 45 mph)
RotorWiki
Old 07-03-2008, 12:36 AM   #14
My break-in procedure...
Moderate stops from freeway speed - i.e. ~60mph x3
Heavy stops from higher speeds - i.e. ~100mph x3
Let the brakes cool down thoroughly after doing this.
Of course, all the usual disclaimers apply...
Old 06-28-2008, 01:45 AM   #15
any more details?
