Old 12-29-2012, 09:29 AM   #1
t2ae
t2ae is on a distinguished road
Exclamation PLEASE HELP! 94 rx7 running ROUGH!
Hello everyone i really hope you guys can help me out. I'll start out with the background and mods as far as i know of the car...
Approx. 100k chassis miles and only 18k on rebuilt engine from revinsevens
Car was originally Montego Blue then painted white. Engine bay is flat black.
Rebuilt 13Brew short block w/approx. 18k miles
All components (alt, manifolds, belts, pumps, etc...) have approx. 40k miles on them.
Tweakit racing idler pulley
AC & Emissions pump deleted.
SS braided oil & power steering lines
Dual oil coolers
Aftermarket Earls oil cooler
Dual Supra fuel pumps
SS braided -8 & -6 fuel lines
Rotary Works full 3" exhaust
Megan 3" DP
Portmatched LIM
Act 6 puck sprung clutch and HD pressure plate
JDM 5 speed transmission w/approx. 20k miles on it
Stance Coilovers
18x10.5 +25 XXR WHEELS
Interior
Cobalt Wideband A/F gauge
Prosport Oil pressure, oil temp, & boost gauges
Rewired fuel pump
Relocated optima red top battery to passenger bin
Custom pearl white paint
Shine Auto Feed Sidesteps
Shine Auto Feed Front Bumper
99spec turn lamps
99spec tail lamps
....with that being said i just purchased this car as is running poorly. It has a jdm harness with american ecu. The problem persist of the vehicle overall running very poorly. sounds like its a bridge port while running even though its not. its running on both rotors as i have verified fuel,spark for both. i have replaced the spark plugs,wires radiator and coolant. now as far as questions go i am having trouble finding out if this is fuel or ignition related. as it does have the dual supra fuel pumps on the stock fpr and injectors. all emmisions are removed with the solenoids still plugged up just not active. there is a pretty bad exhaust leak at the manifold where it meets the block. any imputs you guys could give me would be great. i will be testing the fuel pressure tonight as well.
t2ae is offline   Reply With Quote
Old 12-29-2012, 09:31 AM   #2
t2ae
compression as well is right at 95psi on each face
Old 12-29-2012, 07:20 PM   #3
Topgear
Topgear is on a distinguished road
It could be loads of things mate first I would check you map sensor and all vacuum pipes
95 FD3S Type RB Project BorgBoost 550BHP
93 FD3S Project 26B
1200+bhp rolling road dyno
+44161 4948343
www.tgstuning.co.uk
https://instagram.com/craigtgs/
Car looks jizzfactor3000 good!
Topgear is offline   Reply With Quote
Old 12-30-2012, 09:47 AM   #4
t2ae
found fuel pressure at idle at 75psi
Old 01-07-2013, 03:10 PM   #5
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
That fuel pressure is WAAAYYYYY too high imo! Stock pressure is meant to be 43.5psi.
I'm no tuner or a professional by any means, but I'd seriously look into turning that down.
Maybe i missed it, but what ecu are you running?
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-02-2013, 02:57 PM   #6
t2ae
bump
Old 01-29-2013, 04:41 AM   #7
Negri
negri
Negri is on a distinguished road
Yea true about the fuel pressure it has to be between 40 @ 45 psi if you have a wide band you can tweek it till when its idleing at arround 13 pn air fuel ratio give or take depending on mods and setup
Negri is offline   Reply With Quote
Old 04-24-2013, 11:15 AM   #8
t2ae
so found electrical tape jammed in the primary fuel rail lol. thus causing pressure to be sky high
Old 04-24-2013, 11:40 AM   #9
ElTeeFauci
Tuned by... ME!
ElTeeFauci's Avatar
ElTeeFauci is on a distinguished road
wow... first time I've ever heard of that happening.
Its a big sh!t sandwich... and we're all gonna have to take a bite...
ElTeeFauci is offline   Reply With Quote
Old 04-24-2013, 12:17 PM   #10
t2ae
yea me too, still battling this first start issue though
