| 3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
Don Mega
Control up to 2.5bar gauge boost pressure
Best Boost controller on the market period! Calibrated to show true rwhp as well Comes with custom input harness so the unit is a mini data logger as well! can log boost, AFR, EGT front and rear, power, fuel pressure (use your own sensors) Amazing unit ! Full boxed AS NEW, English Instructions! New silicon hose! and will throw in silicone heat sleeving as well! + full set of set up notes for Tial V44 waste gate set up. $1500 shipped ![]() ![]() ![]() PERFECT BOOST CONTROL! Boost to speed, Boost to RPM, 4 stages, Full Auto or Manual set, this is proven to be the best you can get! No hype! just true real results, if you need an add on boost controller that works this is it! and it is fully set up! ready to go! ![]() ![]() ![]()
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 10-23-2012 at 05:26 AM. |
Don Mega
sold
Don Mega
BUMP, back for sale.
Don Mega
bump
Don Mega
This bad boy is in its original packaging and in tip top condition, its set up to run and everything configured correctly all you need to do is fit it up and BOOST AWAY!
Don Mega
BUMP this, as you can see its all as new.
English instructions and ECU wire up guide for all Jap cars. This is set up and ready to go ........ Will include 6mm push fitting for your intake manifold so its all plug n play, also custom input harness I made so you can log EGT, fuel pressure, etc as per pics in my RICESP! This is the best unit around!
Don Mega
sold!!!
