Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 03-21-2012, 11:50 AM   #1
krivman65
krivman65 is on a distinguished road
How to remove flywheel?
Does anybody have any good ideas on how to get the flywheel off? The engine is currently out of the car so I'm thinking bolt it back in so the other wrench isn't lifting the engine up off the floor... Any and all ideas are greatly appreciated!
krivman65 is offline   Reply With Quote
Old 03-21-2012, 12:35 PM   #2
mazpower
Rawr Bearclaw
mazpower's Avatar
Best way is to use a flywheel lock tool which bolts to the upper part of the rear housing and keeps the flywheel from spinning. Otherwise get a couple friends to help secure the engine while you're breaking the flywheel nut loose, I've done that many times.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 03-21-2012, 12:39 PM   #3
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
I've seen people get them off with a heavy duty impact driver and no flywheel lock.
Old 03-21-2012, 12:44 PM   #4
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
I took some 2" angle iron, drilled holes to match the engine mount holes
on the front cover and bolted it on to stabilize the engine to get the front
bolt out of the eccentric shaft.
You can probably do the same trick with the angle iron on the flywheel as well.
Old 03-21-2012, 04:20 PM   #5
krivman65
Thanks guys! Apparently this is a normal issue... I kind of get a kick out of lifting the engine up with a wrench.
Old 03-21-2012, 06:16 PM   #6
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
If this is the first time the flywheel has been taken off the engine since the factory...
There are 2 issues.
#1 getting the flywheel nut loose.
#2 getting the flywheel off the e-shaft.
With getting the Nut loose, there have been many tales of different ways to do it. All of which aren't a bad way to do it. If you can get it off that way, great.
In my experience, I've had someone stand on the engine while I hit a breaker-bar (that's attached to the 2&1/4" socket) with a BFH.
Then once you get the nut off, you might be surprised that the flywheel won't just pull off. So what I have done is hit the edges with a BFH, working it around in a cross pattern. You can use a peace of wood between the flywheel and BFH if your concerned with damage to the flywheel surface. After that it should pull off.
Just putting my 2 cents in.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 03-21-2012, 08:26 PM   #7
Ask Kevin about that. He had to secure the engine while I took one of your cherry picker legs for leverage
If it's big enough it will work no worries.... mine is big enough
There are 2 issues.
Skip the wood, get a brass hammer. It needs the shock to be able to free itself. The wood prevents that..... or lessens is I guess
Old 03-21-2012, 07:21 PM   #8
rxspeed7
The fan hit the shit!
rxspeed7's Avatar
rxspeed7 is on a distinguished road
Get it loosened how ever you can. I have always used a impact or a flywheel locking tool and long ass pipe.
Then thread bolt back on a few threads, and then whack the shit outta the flywheel with a heavy heavy hammer. Make sure you do it evenly around the flywheel. The harmonics through out it will break it off the chamfer
87 TII= High comp 13b-re,S360,Link G4 RX
I suppose you could orally BDC or even anally BDC someone? or be BDC'd in those two ways also
Many ways you can get BDC'd
rxspeed7 is offline   Reply With Quote
Old 03-21-2012, 07:35 PM   #9
mazpower
Rawr Bearclaw
mazpower's Avatar
In an effort to keep from hurting the flywheel by banging on it, I choose to use a sacrificial e-shaft nut and bang on that with a sledge while prying the flywheel off with a large prybar. Even on a virgin flywheel, it takes about 4 good whacks and it pops right off. This has always worked great for me.
Illicit Performance
Old 03-21-2012, 11:29 PM   #10
krivman65
Well sounds like I need a BIGGER BFH and somebody to stand on the engine for me... Thanks for the help everyone!
Old 03-22-2012, 11:33 AM   #11
Almost any impact gun - 1/2" or bigger - will get the flywheel nut off.
My Craftsman Pro *electric* impact gun has taken off flywheel nuts, and it's only rated at 250 lb.-ft.
If the flywheel nut is stubborn, use some heat - i.e. torch - to help.
Once the flywheel nut is loosen, it's just a matter of banging it with a hammer or equivalent.
If you still can't do it, you need more muscles - don't blame the hammer.
I've gotten the flywheel to loosen with a *regular* hammer - not a mini sledge.
You need to just WAIL at the flywheel like you're going to kill it.
Keep away from the clutch disc mating surface areas and the outside teeth (for the starter).
Of course, all safety disclaimers apply here.
Remember, the eccentric shaft end is tapered where it mates with the flywheel.
Pounding it in - towards the engine - will cause the flywheel to bounce back off the taper.
Old 03-23-2012, 05:05 PM   #12
krivman65
I haven't had a chance to get back out there and attack it yet but the thought occurred to me- Does that have right-hand threads?
Old 03-24-2012, 04:45 AM   #13
It's your typical lefty-loosey, righty-tighty thread.
It's not a reverse thread.
Old 03-24-2012, 11:14 AM   #14
krivman65
Ok cool. I am going to go attack it this afternoon...
Old 03-25-2012, 01:17 AM   #15
krivman65
Well after lots of grunting, sweating, and bleeding... we gave up and ended up using an impact. I bought a flywheel holding tool and it didn't help either. Man you guys weren't kidding! And of course, there was lots of beer drinking afterwards in celebration of removing said nut.
Thanks for all the help!
