Old 01-16-2012, 06:09 PM   #1
Shainiac
Shainiac's Avatar
Shainiac is on a distinguished road
FS: S5 TII Trans, S4 TII LSD, S5 OMP, S5 Engine Parts, S5 Ext. Trim, and MUCH More!
Everything is located in Indianapolis, IN. If you are local, we can work something out to avoid shipping some of the heavier parts, or I can drive +/- an hour if you pay for gas.
----->All prices are OBO and do not include the shipping price.
----->For fastest response, PM me
----->PICS ARE AT THE BOTTOM
S5 JSPEC TII Transmission
-Motor had about 30k miles on it (Apex seals measured .300” out of 315” new)
-Comes with Throwout Bearing/Shift Fork
-Note: Someone painted the engine in the car, along with the bell housing. The trans is half black, NOT oily. I can pain the rest if it’s an issue
$300 + shipping
S4 TII LSD (Clutch-Type)
-Pulled from a stock ’88 TII, 66K MILES.
-No drift shenanigans
-Spins freely with no noise
$300 + shipping
S5 OMP (2 Available!)
-TESTED! Passes the FSM resistance test. One has useable low mileage lines in good shape.
$60 each
$75 with the lines (or $20 if you just want the lines)
S5 Trim Set #1
-Painted black, Includes every piece for S5 conversion, but some are missing clip(s). Every piece does have at least 1 clip (even very small pieces)
$60 + shipping
S5 Trim Set #2
-Red
-Only a partial set --->Misc Passenger side pieces + 1 drivers side piece.
-All the clips are unbroken!
$25 + shipping
S5 NA Engine Wiring Harness Converted for TII
-Came off of a friends NA->TII conversion
-cleaned and re-wrapped with 3M electrical tape
$60+ shipping
S5 Turbo Oil feed Line
-A bit scraped up, but no holes. Includes banjo bolt.
$10 + shipping
S5 Turbo Water Pump Housing
$20 + shipping
S5 Waterpump Neck
S5 Waterpump Neck
-No cracks or chips. No pitting.
$15 + shipping
S5 TII Front Cover
-Comes with a good CAS!
$45 + shipping
S4 NA rotors
-Good bearings, no damage. Completely usable.
$100 for the set + shipping
S5 NA TPS
-TESTED! No dead spots.
$30 + shipping
TII Trans
TII Diff
[SIZE="4"][B]S5 OMPs
S5 Trim #1
Trim Set #2
[/IMG]S5 WP Neck
S4 NA Rotors
S5 NA TPS
Shainiac is offline   Reply With Quote
