newbie trying to choose a 13B
Hi guys! need some advice on choosing a 13B for my project RX2. I have been reading a ton and i decided i would like to build a 13B because of the larger displacement and the aftermarket parts that are avalible. More bang for the buck. I didnt realize that they made so many 13b motors. I would like to build a NA street/strip motor. 13b, AP, 13B-RESI, 13B-DEI, 13B-REW, 13B TII, 4 port, 6 port??? I realize some of these are turbo motors and Fuel injected motors. Just not sure what would be the best foundation for a NA mill capable of someday making 200-250HP? Whats a good 13B for a Rotary newbie? As always any help is appreciated! Thanks!!!
yes they did update the 13B over the years, but the good news is that most of the updated parts are things like the rotors and stationary gears, which fit any 13B, so it makes just about any 13B worth building.
if you want EFI it would be best to use an 86 and newer engine, they have injector holes already (and injectors and a fuel rail). ideally you want the 4 port irons. the 6 ports dont respond to porting very well, so they are more power limited. the 89-91 non turbo rotors are the lightest, and highest compression the 89+ stationary gears are hardened from the factory, the 89+ tension bolts are nicer too the FD bearings are better, you can pick a tighter clearance the condition of the parts is actually the most important thing, the irons need to be flat, rotor housings need to be good preferably new, new seals, etc etc |
Thanks or the info! Im leaning toward a 4 port for sure. I would love to play with a turbo motor but this is the first rotary I've ever played with so i wanna keep it kinda simple the first time. After i learn the ropes I will look into turbos. Anyone know were I can find a list of years,makes,models that came with 13b 4 ports? sounds like it might be the best place to start! lol Thanks for the reply! I was starting to think no body would
Rep Power: 10 ![]() |
Efi 4 port engine are in turbo cars from 87 and up. Benefit is, if you build the engine and ecu, fuel injection and ignition system properly, after you're done playing in the n/a world, you can bolt on a turbo and have some real fun
#5 | |
Rep Power: 20 ![]() |
I have Ultra power in me.
Rep Power: 15 ![]() |
As am I, except I'm doing it the "normal" way. Using the TII intake on an N/A block and port matching the LIM. I went a step further and decided to use a standalone rather than stock TII parts (ECU, AFM, boost sensor) with a FCD.
I like the way you think TitaniumTT!!!!!!!
#9 |
Are you planing on building one?
#10 |
#11 |
And its one of the biggest hack projects I've seen.
I can't weld aluminium, so I'm gonna build a mani out of steel and coat the inside.... let's use a megasquirt I hate that project
#12 |
In general the best foundation is a 4 port (87-91 TII engine) that is N/A. However, it's so simple just to get a boosted rotary and make 200+ all day with basically 0 work.
#13 | |
I was told you can make good power with the N/A rotors in a 4 port engine with a turbo. I think the s4 NA rotors are 9.4 and the S5 is 9.7. and the S4 turbo is 8.7:1 and the S5 is 9.0:1. those where off the top of my head. The RX8 rotors are 10.0:1 but they need to be machined to work in a older engine. I know the apex seals are different and I believe the corner seals will cause you issues. It is just easier to run the 9.7:1 S5 N/A rotors.
here is the ratios and weights, I was off a bit. Quote:
Last edited by Raksj04; 11-30-2011 at 05:41 PM. Reason: ratios off, quoted a sticky |
#14 |
Don Mega
13B-REW and a 300bhp shot of Nitrous Oxide is what you need
#15 | |
