Old 07-03-2011, 04:33 PM   #1
sen2two
KTEC
sen2two's Avatar
Eating clutch master
My car seems to eat a clutch master cylinder every few months. I cant see any reason it would be doing this except for one thing. I had a clutch line made and it kinda extra long for no real reason except for i guessed the length instead of measuring it. And its more of a rubber brake line material not hard lined or braided. Could an extra long clutch line cause the cylinder to over work and fail? Also it being non steel braided and not hard lined making it flex causing the cylinder to work even harder.
I have no other idea why it would be doing this... any ideas?
what I have:
What I had:
Old 07-03-2011, 07:05 PM   #2
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
it shouldnt the fluid in the line should take up the extra space and master should just have to create the same pressure and movement to make slave move, might just be bad parts! but i have a master, hard line, soft line and slave for sale make offer, just saying lol
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 07-03-2011, 07:06 PM   #3
No, that's silly
Your pedal is probably out of adjustment causing the cylinder to go down too far, or not far enough.
Are you sure the master is puking? Is it leaking? What fluid are you using?
Old 07-04-2011, 02:04 AM   #4
It's not the line unless the lining is causing the failure - i.e. particles falling off or reacting with the brake fluid?
Longer or softer clutch lines actually help with the reliability of the whole system.
Some race teams will run softer (i.e. rubber, non-braid / non-hard line) on the clutch hydraulics to help minimize the "shock" of the using the clutch pedal - this is especially true on endurance racing.
Old 07-04-2011, 09:52 AM   #5
sen2two
KTEC
sen2two's Avatar
I had three master cylinders go bad in a year. And I don't drive it more than 3-4 times a week. I know its the master because when I change it, the problem is solved. For fluid i use whatever i have on my shelves in the garage. I don't really drive it hard too often. Only when it sees the 1/4 mile really. And that's every few months.
So you guys agree on pedal adjustment being the problem?
what I have:
What I had:
Old 07-04-2011, 06:23 PM   #6
Where are you getting the replacement clutch masters from?
If you're getting it from the neighborhood auto parts store, beware of inferior "rebuilt" / "remanufacturered" units.
A lot of these cheapie reman units have very bad quality control.
If you want to check, disassemble them and check the bore smoothness.
If they are bad, the bore will be pitted, and this will eat any new seals in a jiffy.
Old 07-05-2011, 08:07 AM   #7
sen2two
KTEC
sen2two's Avatar
the first one came with my front clip swap. The second one I pulled from a parts car I had. The third one was the original from the car when I first got it.
so they are all used, but it's a little too coincidental for them all to be bad or worn out.
what I have:
What I had:
Old 07-05-2011, 05:13 PM   #8
Are the rest of your hydraulics in top shape - i.e. brand new and just swapped out?
If so, I can believe all 3 of them would fail.
Stop messing around with that used crap and get a rebuilt one from the auto parts store.
Old 07-05-2011, 09:28 AM   #9
My5ABaby
My5ABaby's Avatar
If one that old is bad, it's not coincidence when more are, it's expected. I just helped a friend who had 3 bad FPRs in a row, but all used. He put on a new one, fixed. if it's a 50% chance an old one is bad, after 3 that's 12.5%. Kinda rare, but not ridiculous.
Community Service Manual
RotorWiki
Old 07-05-2011, 11:18 PM   #10
NoDOHC
NoDOHC's Avatar
If you let a hydraulic component (brakes or clutch) sit around without any fluid for very long, it will go bad, even if it was fine when removed. What happens is that the seals dry out and crack, the component works for a short time, but fails very quickly.
The linkage is easy to adjust, I make it engage just as the spring assist is reaching the neutral point, the cylinder should be Ok for a pretty good range of motion though.
Old 07-05-2011, 11:39 PM   #11
The last 2 posts are spot on, you're putting on parts that you don't know the history or condition of. I'm blaming the parts here, not something being out of adjustment. Buy a rebuilt one, check the condition of it, and be happy for a long time
Old 07-06-2011, 09:27 AM   #12
sen2two
KTEC
sen2two's Avatar
Your all wrong and stupid!
lol...Just kidding. I'm on my way to the store now to get a new one. But i doubt they will have one on hand.
what I have:
What I had:
Old 07-07-2011, 10:06 AM   #13
Just one cavaet...
If this is the first failure in your (clutch hydraulic) system, be prepared to spend more money and more time in fixing everything.
This is especially true if all your components - clutch master cylinder, slave hose, clutch slave cylinder - are all original.
This is the weakest-link-in-the-chain scenario...
The weakest part of the hydraulic system fails first.
Once you replace the part that fails, the new part is stronger than the rest of the others and puts more stress on them, causing them to fail eventually.
Old 07-07-2011, 04:51 PM   #14
Pete_89T2
Pete_89T2's Avatar
^Roger that. The good news is the clutch hydraulics parts, even new, are relatively cheap. I recently replaced mine with new master & slave cylinders (Beck-Arnley OEM replacement parts), plus shipping came in at about $50 from Rockauto.com. Quick & easy job too.
Old 07-25-2011, 08:09 PM   #15
Ok, guys come on even rebuilt is stupid. The clutch master and slave are each around $50 brand new from Mazdatrix, why would you even consider rebuilt it it's roughly the same price? Working at a dealership for a while, I came to trust the quality of oem parts a lot more, after seeing so much aftermarket crap fail after only a few years, even months, on the road.
Originally Posted by mazdatrix site
The Clutch Master Cylinder and Slave Cylinder do wear out. We have not seen satisfactory (100%) success when they are "rebuilt." Our preferred choice is to replace worn/leaking cylinders with new, although we do carry rebuild kits. The rubber flex line to the slave cylinder should also be closely inspected for deterioration and replaced if not in excellent condition.
