Old 06-30-2011, 12:11 PM   #1
Oil-cooled only turbos?
No go on a rotary?
Old 06-30-2011, 12:45 PM   #2
Funny you are posting this now, as I had the same question.
Since I am boosting the 12a, and I have to find a source/return for coolant I did some research on it.
The JDM 12aT had a very similar turbo as the S4/S5 FC's, a Hitcachi HT-18. They did not have coolant provisions, oil only.
So, after asking around to a few guys with 12a turbo set-ups, most do not run coolant on theirs.
I am taking a gamble, and am going to rum it oil only.
PS- Nate, I need that S4 manifold!!
Old 06-30-2011, 12:48 PM   #3
Haha I know you do. Are you planning on trying to run the twin scroll or not?
Old 06-30-2011, 12:56 PM   #4
No twin scroll for me!
I am still collecting parts, so no biggie. If I NEED it, I will PM you some $$$ for shipping.
Old 06-30-2011, 01:09 PM   #5
mazpower
Rawr Bearclaw
mazpower's Avatar
I've been running a Turbonetics T-66 non BB turbo on my FD since '07. Its not water cooled. Just be mindful of the turbo and you'll be ok...drive easy the last few minutes of your drive, let the car idle for a minute or so, and change your oil frequently. If you beat on it, give it 3-5 minutes of idle before shutting off. You'll be fine.
Illicit Performance
Rotary building, porting, tuning, chassis dyno services
www.illicitperformance.com
Old 06-30-2011, 01:13 PM   #6
Good to know. I have been looking at a few oil cooled only to4e turbos and wasnt sure of how big the downside was.
Old 06-30-2011, 02:14 PM   #7
Here is the specs on the turbo...Thoughts?
Compressor: 76mm wheel w/ 50 A/R housing
Center section: Garrett oil cooled only
Turbine: 1.15 A/R divided to4e
Old 07-02-2011, 11:05 AM   #8
You talking about this one?
Whoever is giving you the "specs" of the turbo is an idiot.
I need at least inducer and exducer diameters of the compressor wheel.
The compressor housing A/R is basically useless.
(For turbine side, the turbine A/R and turbine wheel trim is minimum info.)
All the 3" (exducer diameter) compressor wheels I've seen range anything from a T04B S-trim (which is basically the same size as the stock Hitachi HT-18) all the way up to a 60-1 / 62-1.
So you're talking power potentials anywhere from 250hp all the way up to 400hp.
See what I mean by useless?
Old 06-30-2011, 02:55 PM   #9
Pretty big turbine A/R, but you have a healthy street port right?
Old 06-30-2011, 02:59 PM   #10
Water-cooled centers were for paranoid jackasses who were scared of oil coking due to shutting off the engine after a hard run.
NONE of us do that, right?
It's the same for turbo timers - remember those?
If you're mindful of "cooling down" the turbo, then there is no need for the added complexities of a water-cooled center.
Old 06-30-2011, 03:06 PM   #11
Meh its a racing beat template mild street port. Charles knows the specifics since he did it lol.
Old 06-30-2011, 05:59 PM   #12
Mazdabater
FC3S
Im looking at getting the EFR-9180 from BW. Ive noticed it says "water cooling optional but reccomended" so there is no real gain aside from when you shut it down? Because when i installed my current turbo I blanked off the water outlets on the engine for the turbo lol
Old 06-30-2011, 06:59 PM   #13
730RWHP12A
no water needed for turbos to last, save the water for the fish
rotaryshack.com
Old 07-03-2011, 09:41 PM   #14
PercentSevenC
Custom User Title
PercentSevenC's Avatar
So does this also apply to turbos with water-cooled CHRAs, such as a stock FC turbo? Because I'm not running water lines to my S5 turbo. It hasn't died yet.
Old 06-30-2011, 07:18 PM   #15
What is anyones thoughts as far as the listed turbos size considering its going on a mild streetport 13BT.
