Old 04-08-2011, 12:51 PM   #1
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
Exclamation RB Holley setup, Carb and Dizzy Tuning Help
1984 12a think its street port but not sure, 465 cfm holley. header back single exhaust, upgraded coils. Where do the vaccum advances get vaccum from and do one or both need to be hooked up rb says trailing only but that sounds wrong. also how do i setup the carb correctly (tune it) and what timing should i be runing. Right now car wont ideal under 1500 and wont cold idle. Any help is greatly appreciated.
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline   Reply With Quote
Old 04-09-2011, 01:32 AM   #2
FC Zach
FC Zach's Avatar
I dont hook up the vacuum advances, I set the timing at 5-6k RPM which is where the weights should be engaged and I'll have to get back to you on where I have them set at that RPM (my notes are in my car). As far as setting up the carb, I would first set the timing so it will idle. Once it can idle set the fuel pressure and floats. Then you can play with the Idle/Air mixture screws. I generally turn them clockwise (slowly) till you to hear the engine start to die and back them off a 1/4-1/2 turn. This should get you in the ballpark.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 04-09-2011, 07:02 AM   #3
IH8DSM
IH8DSM's Avatar
What zach said also have a set or two of spare leading plugs you'll need em when you start tuning. Also your rb Holley should have a DVD with it(mine did anyways) that tells you how to set the floats change the jets etc. Also while tuning look at the plugs and it'll give you a idea how rich/lean your running
As for the vacuum advances I know several people that don't run them so I'd say f it haha.
Old 04-09-2011, 09:20 AM   #4
TS87FC3S
TS87FC3S's Avatar
i set the timing at 0 degrees at idle with vaccum advance hooked to both advances and the car idle super smooth (1100 rpm cant get it any lower) and runs great whats the deal with not hooking up the advances?
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
Old 04-09-2011, 11:30 AM   #5
FC Zach
FC Zach's Avatar
Alright I set my timing to 23* before top dead center on the Leading and 8* before top dead on the Trailing and at 5k RPM. I don't hook the vacuum up because I find it redundant.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 04-09-2011, 06:31 PM   #6
IH8DSM
IH8DSM's Avatar
Check your gaskets and vacuum ports on carb sounds like a vacuum leak mine I can make it idle close to 600 rpms. Make sure the carb to intake gasket is good
Old 04-09-2011, 10:15 PM   #7
TS87FC3S
TS87FC3S's Avatar
sprayed throtlle body cleaner (extremely flammable) while running no change in rpms, so i would say gaskets are good i can change timing and have it idle lower
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
Old 04-09-2011, 11:51 PM   #8
FC Zach
FC Zach's Avatar
Any improvment?
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 04-10-2011, 01:56 PM   #9
TS87FC3S
TS87FC3S's Avatar
Originally Posted by FC Zach View Post
Any improvment?
havent had time to mess with it yet, i will do it tomorrow and let u know
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
Old 04-14-2011, 07:09 PM   #10
TS87FC3S
TS87FC3S's Avatar
did timing the way u said fc zach car started running hot and had a horrible low end no improvement to upper end, so i set it the way racing beat says too no problems runs great, just need a regulator now fuel pressure is fluctuating alot
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
12a carb timing tuning
