Turblown Engineering
Just Shy of 500rwhp
TD61( GT35R Comp, P trim turbine 1.15 a/r) 22psi
Small Street Port Inconel Heat shields 3.5" exhaust MSD ignition Greddy FMIC Pulls hard on street, 285s aren't enough... |
Alot of work payed off .I guess wider tires are next on the list .
Don Mega
Fuel used? other specs?
Would love to see a video of (3rd to 4th gear) 60mph to 130mph or 100kmh to 200kmh along with times........
109 octane, dual walbros, stock 550s/2200 secondaries, 77 % duty cycle.
We are reflowing injectors to work out the bugs. I can tell you this it spins the tires @ 80mph in 3rd gear. Will look into getting videos of those times... |
Don Mega
Good stuff
![]() We have to start up a list here of cars that do 60mph to 130mph like many other enthusiasts do. Race Logic Performance Box is a cheap way to obtain the data and we can collate a "RCC record list". http://www.rotarycarclub.com/rotary_...ead.php?t=1263side note: what AFR at 6500rpm and timing? if you care to share?
www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 02-17-2011 at 08:09 PM. |
Afr was 11.7, timing was really low, around 6-8 degrees. We changed the split then ended up having issues..
#8 | |
Don Mega
Keep up the good work, I like reading your posts, seeing the pictures and videos
#9 |
Bubble Tech
what ecu are you running? what did u do to get rid of the coolant buzzer?
#10 |
PFC, coolant buzzer is hooked up in that custom thermostat neck...
Otherwise you can just ground it on the harness.. Funny thing is I tuned another car to 607rwhp the other day, and it made the same torque as this car.. |
