Bac
what is the hose that exit on the bottom of the BAC supposed to connected to?
It connects to "splitter pipe" that has the stock blow-off valve connected to it.
-Ted |
So i should connect it somewhere between turbo and tb's then?
Simply Rotarded
yes
LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!! |
Thanks for the answers
Expect more questions in the future since i'm a new when it comes to rotarys..
Compression Tester Man
Rep Power: 17 ![]() |
This is what the hose looks like when connected to the OEM intake piping.
Prepare to get a good idle when you connect the hose
![]() Dette er igrunn "tomgangsmotoren". |
Ja den har ikke vært helt bra kan du si :P
Hvor i norge holder du til? |
#9 |
PM
