Old 07-07-2010, 01:11 PM   #1
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Body work, '89 rx7 gtu.
So I finally did something about the dents in my fenders on my gtu.
This was done rough.
At first I thought I was going to paint the whole car too, but that has to be postponed.
Anyway.
There was a bracket that was disconnected from the frame that held part of the fender.
I fixed that.
Crappy welds, I know. Haven't been welding long. But it holds, I can shake the car with it.
I missed the color match a little. lqtm.
Ill be back.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 07-08-2010, 09:30 AM   #2
N.RotaryTech
Home-brew Rotary
Fender dents removed.
Before an after.
All I did was take a hammer to the inside of the fenders.
Also epoxied the crack.
Old 07-09-2010, 12:29 AM   #3
project86
Can't.Make.Up.My.Mind.
project86's Avatar
i wouldnt count on that epoxy to hold the way you did it. i can offer an alternative though if youd like
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 07-09-2010, 06:03 AM   #4
N.RotaryTech
Home-brew Rotary
Ok,
I had the bumper off, found a way for the crack to be held together, then put epoxy on both the inside and outside, also worked the epoxy inside the crack.
Had a friend mention to me, use the fiberglass resin an cloth method. But I decided to do epoxy instead.
What's the alternative?
Old 07-09-2010, 08:43 PM   #5
project86
project86's Avatar
Originally Posted by N.RotaryTech View Post
Ok,
you dont want to use fiberglass resin and matte. that will be much to rigid and will probably crack on that bumper if it even sticks.
My suggestion, and the way i was taught in school, (the right way to do it as far as im concerned). V out the crack on the front and back with a die grinder or some coarse sand paper. Get a role of plastic mesh ( should be able to get it from you local auto paint store) along with some plastic fusor. the brand im familiar with is LORD Fusor 142. Its a 2 part like alot of epoxies but its a plastic repair material for this type of application specifically. you do need a gun for it similar to a caulking gun.
Start with the backside. Apply the fusor generously to the back side of the crack. I say try to make it seep through to the front side so you dont have to re apply the fusor to the front. After you have applied the fusor put a piece of the plastic mesh(big enough to cover the whole crack) on top of the fusor.) you might want to apply some more of the fusor on top of the mesh and spread it around just to make sure you have the crack covered.
Keep in mind this fusor does have a fairly short working time, meaning it will harden fairly quick.
Once the back is all dried up flip it over. If the fusor came through enough on the front side you should be able to sand it smooth and the crack should be gone. if not generously apply more on the front and spread with a squeegie to make sure its covered. You will need to sand it once its tried.
You may want to get another type of fusor to go over the top of the 142 for the front side. I cant remember the number of it but its make by the same company and its red in color. this stuff is like a plastic friendly filler. I recommend it if you dont mind spending the money on this whole process. It comes in a white tube and you dont need a gun for it because it has both materials in the tube and mixes as it comes out.
Ill get off my soap box now. Hope this helps
'90 GTUs
'10 Toyota Prius
Old 07-15-2010, 06:15 PM   #6
classicauto
crash auto?fix auto
classicauto's Avatar
110EZ
FWIW, I've found the TPO plastics on our bumpers dont repair the best. This will work by all means - but if perfection or long term hold out is what you're after, I'd toss the cracked cover. You can try welding them, I've had good success on FC/FD bumpers with that.
Old 07-19-2010, 09:04 PM   #7
project86
project86's Avatar
Originally Posted by classicauto View Post
110EZ
good call joe. i forgot about the 110EZ. Youre also very right on the cracked cover. Repairing that type of damage is do-able but not always time friendly and 100% worry free. In fact, if im not mistaken, manufacturers dont use that type of plastic for bumpers anymore because of this reason and they warp from heat very easily.
'90 GTUs
'10 Toyota Prius
Old 10-23-2010, 06:20 PM   #8
N.RotaryTech
Home-brew Rotary
What I did with my Saturday afternoon!
I decided to fix the old paint on the passenger side fender.
Scraping old paint off. (I really need to get a power sander.) Done by hand again.
Sanded fender. Went with what I had, 150 grit, 220 grit.
Washed, and ready for primer.
Primer.
Old 07-09-2010, 06:15 PM   #9
N.RotaryTech
Home-brew Rotary
I'm going to paint the hood red, so I don't look like a ricer. lqtm.
Sanded it today, with what I had, starting with a 60 grit then a 150 grit.
More car work inside, lqtm, cause I did not want to do this out in the heat.
Now just to find a not hot morning to paint this outside. And I got to play with the weather to find a morning where its not raining.
Can't wait till its done.
Old 07-09-2010, 08:37 PM   #10
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
I am going to say your welder is either a flux core (no gas) or you are just learning the basics of it... either way looks good..
one question though..
what does "lqtm" mean, you wrote that 3 times, and I am not even remotely sure what it means..
cheers..
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 07-09-2010, 08:44 PM   #11
project86
project86's Avatar
Do you have Dual Action sander?
'90 GTUs
'10 Toyota Prius
Old 07-10-2010, 03:05 AM   #12
N.RotaryTech
Home-brew Rotary
Can't sleep post!
My welder.
I am using the flux core wire.
I do have gas but I haven't acquired the right connection fittings yet.
lqtm, is something I leaned on the internets, stands for "laughing quietly to myself".
Most of the time I'm not really "laughing out loud" (lol). So it fits.
Interesting about the Fusor stuff, never heard that before.
I don't have any power sanders.
I did the sanding all by hand.
Old 07-10-2010, 10:50 AM   #13
project86
project86's Avatar
You probably havent heard of it because alot of DIY people (when it comes to body work it seems) dont learn from people that actually know how to do collision repair the correct way.
If you can try to get a DA if you have a compressor that will run it. Otherwise there is a very good chance that you will see alot of your sanding scratches through the paint. The DA will sand in a very small "swirlly" patern if you will. So when it comes time for paint and primer if youve sanded with fine enough paper you wont see sand scratches. Judging just by the picture of your hood, which is sometimes hard to do since you cant see small things, the paint looks to be in good shape so you probably dont need to prime it. But it never hurts to.
EDIT: Also on your welding i noticed that you didnt sand any of that paint off before you welded, or at least it didt look like you did very far. It should weld better to clean bare metal instead of trying to go through paint.
Hope ive been helpful
'90 GTUs
'10 Toyota Prius
Old 07-10-2010, 11:14 AM   #14
N.RotaryTech
Home-brew Rotary
About the weld, yeah, I should've cleaned the metal farther. Inside the circle was clean. but above wasn't done far enough.
Old 07-14-2010, 11:09 AM   #15
N.RotaryTech
Home-brew Rotary
Note to self: Don't go as low as 60 grit, and go finer than 150 grit before paint. Duh.
