Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Team ultraracing(USA)
Old 06-27-2010, 07:21 PM   #1
nortonuk
nortonuk is on a distinguished road
Team ultraracing (USA)
Hello Rotary car club ,
We are proud to be a new vendor on your forum .
Our company has grown fast over the last few years ,We started in 2002 in Malaysia and in the last few years we have moved across the world .
Ultraracing can now be found in , Japan ,Hong Kong,Thailand,Indonesia ,
Philippines,Twian,Australia,the U.K ,Greece,Sweden,NewZealand and now the USA .
Our Goal is to provide the best customer service that we can and high quality Products . We have a large line of products for most cars on the streets .
Our products are designed to be used on the track and the street.
We are a proud sponsor of FXopen Malaysia Drift .
Here is a list of Mazda Chassis that we manufacture parts for:
Mazda 2
Mazda 3
Mazda 323 BF(1986)
Mazda 323 BG
Mazda 323 Astina
Mazda 323F Lantis
Mazda Miata (MX5)
Mazda MX5 NC (2007)
Mazda RX7 FC
Mazda RX7 FD
Mazda RX8
Parts for the RX8
Front 29mm sway bar UR-AR29-079 (solid) $299.00
Rear 19mm sway bar UR-AR19-092 (solid) $199.00
Front four point lower brace UR-LA4-264 $179.00
Middle Lower four point brace UR-ML4-265 $149.00
Rear Lower four point brace UR-RL4-266 $179.00
Rear Strut bar UR-RE2-116 $139.00
Parts for the RX7 FD
Front four point lower Brace UR-LA4-661 $179.00
Rear four point lower Brace UR-RL4-662 $179.00
Rear 19mm Sway Bar (solid) UR-AR19-088 $199.00
Parts for RX7 FC
Fender brace set UR-FD3-353 $159.00
Rear 19mm Sway bar UR-AR19-104 $199.00
****** ALL prices as quoted are shipped in the 48 states ********
How It Works
Understanding Between Chassis and Handling
A car chassis is carry by 4 wheels and 4 shock absorbers. When driving on bumpy road, the shock of impact will be absorb by shock absorber, however if the chassis is not strong enough to support the shock absorber, the shock of impact will not all absorb by shock absorber but by chassis, causing chassis flex. Same thing happen when make a turn on corner, chassis will be twisted by the force of weight transfer. Therefore, the handling will be rough and hard to predict the movement of car.
To soft the chassis flex problem and improve the handling, the Ultra Racing’s chassis strengthen parts is born, we will explain how this product works on you car. The stronger chassis, the better handling.
Strut Bar and Lower Arm Bar
BEFORE:
Part of the shock of impact transfer to the chassis, causing wheel house and lower arm deforming.
AFTER:
Equip with the Ultra Racing’s strut bar and lower arm bar, both side shock of impact will be neutralized.
While entering at corner
BEFORE:
The weight transfer and force gathering on one side, causing unstable handling and increasing body roll.
AFTER:
The force will spread out by Ultra Racing’s strut bar and lower arm bar, stabilize the car and provide solid handling.
Fender Bar
BEFORE:
The joint between A-pillar and front chassis will be push and twist by the greater shock of impact and drag force, causing damage on chassis.
AFTER:
Ultra Racing’s Fender bar will spread out the force and strengthen the section, prevent further damage and offer stable handling. Recommend for user of sport absorber
Side Lower Bar
BEFORE:
On uneven / bumpy road, center section chassis will have different level of body flex cause by the weight transfer between front and rear.
AFTER:
Ultra Racing’s side lower bar will stabilize the weight transfer between front and rear, it can also minimize the damage from side impact.
Anti-Roll Bar
BEFORE:
When turning in corner, the weight transfer will make the car sway a side, causing body roll and more difficult to turn in to a corner, weaken the steering respond.
AFTER:
The upgrade version of Ultra Racing’s anti roll bar will be more effectively preventing the car sway a side at cornering, greatly reduce body roll and high stability in cornering
IF there is anything that we can help you with please feel free to post or pm me .
If need out side this forum please Reach me at :
Sales@ultraracingusa.com
www.ultraracingusa.com
Tel:717-965-6242
Best regards
Mike Barton
nortonuk is offline   Reply With Quote
Old 07-01-2010, 11:24 AM   #2
nortonuk
We will have all our prices listed for the RX8,FD and FC.
We would like to offer a part sponsorship for 1-RX8 with our full line of parts if interested please post some high res images and any info about your car that will help it stand out from the crowd .
We would like to offer the same part sponsorship to any FD or FC .
Old 07-01-2010, 06:06 PM   #3
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Prices? Pictures?
Old 07-03-2010, 02:37 PM   #4
nortonuk
Pm sent thank you for your interest.
Originally Posted by Force13b View Post
Prices? Pictures?
Old 07-01-2010, 11:41 PM   #5
welcome...can't wait to see more FC parts. Specifically the underside bars...Also, I like your "How It Works" section. Good luck and keep up the good work.
Old 07-03-2010, 02:18 PM   #6
nortonuk
Thank you for the Welcome Phoenix 7 we are glad to be here .
If there is strong interest in the FC chassis we will make parts to fill the need.
Old 07-03-2010, 02:07 PM   #7
nortonuk
Parts for the RX8
Front 29mm sway bar UR-AR29-079 (solid) $299.00 and
Front four point lower brace UR-LA4-264 $179.00.
Rear 19mm sway bar UR-AR19-092 (solid) $199.00 and Rear Lower four point brace UR-RL4-266 $179.00 and Middle Lower four point brace UR-ML4-265 $149.00.
Old 07-03-2010, 02:11 PM   #8
nortonuk
I will see if i can get some Images of the parts on the FD as well
Old 07-03-2010, 02:15 PM   #9
nortonuk
Parts for RX7 FC
Looking for a good image of the sway bar ,But our bars are made to bolt in the oem place and use all the same lines as the oem parts so our fitment can be the best.
Old 07-22-2010, 12:42 PM   #10
nortonuk
Ok we just revived the first two sets in for the RX8 in the USA ...
Our first two sets we will let go at a very low price just to get some feed back from you about our parts .
Each set will come with :
Front lower brace
Middle lower brace
Rear lower brace
19 mm rear solid sway bar
If your interested in our offer please pm or call me ....
Our prices will not be listed for this offer !!!!
Old 09-03-2010, 03:19 PM   #11
nortonuk
Wow 290+ views and no interest !!
No one has any questions ?
Old 09-03-2010, 04:59 PM   #12
I'd like to chime in and say I am waiting to see if you develop the front, middle and rear bar set for the FC. I like the fender brace as well but the other parts are the ones I have not seen before.
I assume the prices do NOT include shipping to the US...but $500 to $600 for these parts isn't bad at all. I am keeping an eye on this thread and seeing if you end up developing them or offering a Group Buy.
Old 09-03-2010, 05:58 PM   #13
nortonuk
We would be happy to work on the Brace set for the FC chassis ,if there was strong interest ?
AS for shipping to the USA ,our USA is based in central PA .
All our products are shipped out of our USA warehouse.
Old 09-03-2010, 07:53 PM   #14
How many people would you consider to be enough interest? Maybe we can round up a few members to get it going.
Old 11-03-2010, 11:27 AM   #15
nortonuk
Ok that time of year again .. Sale time !!!!
Would like to offer our RX7 package !!
Front lower brace 4 point $179.00
Rear lower brace 4 point $179.00
Rear 19mm sway bar $199.00
total shipped 48 states $557.00
SALE price one month only $445.60 total savings of 20%!!!
