plugs a little white, when i pulled them out?
i have an 84 gsl se 1.3 resi, i pulled my plugs and the are a little white. how do you add more fuel with the fuel injection, and which plugs should i be using?or am i having a different problem all together? please help me out! thanks
Rotary since 1972
Depending on the whiteness you could be fine. As long as your exhaust temps are OK and you are not over heating I wouldn't be too concerned.
You can richen it with the mixture control. Located just aft of the air filter box. It is a recessed screw in a brown case. There were two curved arrows also showing an L and R. It does not take much to make a drastic change. If you really have to do it in slot sized increments. In lieu of that you could add a little Redline Two stroke race oil also. That would richen it up. |
