Go Back   Rotary Car Club > Tech Discussion > RX-7 2nd Gen Specific (1986-92) > Archives
Archives All the stickies in one place
Old 06-12-2010, 04:02 AM   #1
RX8 Front cover mod for 13B and 13BT
I was talking to Higgi about my issues with the pulley boss and how I needed to remove the front cover to make sure the needle bearings were seated right before torquing the new pulley boss. Long-story short I needed a new gasket and he mentioned that the RX8 gasket was a better choice but it needed to be modified. Very easy.
Have to cut the sections that don't line up without damaging the crush ring (hotlinking pics isn't working anymore)
The info came from this site:
http://www.rotaryheads.com/modificat...asket_mod.html
1. the RX8 gasket is metal vs. the paper ones for the FC
2. The FC front cover gasket is $25 + $4.75 for the Water pump housing-to-block gasket vs. $16 for the RX8 gasket W/ waterpump gasket.
3. It should help with the common leaky front cover.
I'll post pics of it if you want but it's self-explanatory, plus the pics from the site in the site are clear enough
End results:
You can find the gaskets from Atkins:
http://atkinsrotary.com/store/catalo...p-1-c-800.html
Note that this also works for the REW.
Old 06-12-2010, 05:33 AM   #2
FC Zach
FC Zach's Avatar
Nice, I learn something new every day. Going gasket less is an even cheaper and just as effective option, with little modification. I like the fact that the 8 gasket is made of steel. Is it a design similar to head gaskets?? like thin multi layer and coated gaskets?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 06-12-2010, 06:04 AM   #3
Ender
rotors excite me
Ender's Avatar
HA! Cool. I'll have to remember this.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 06-12-2010, 07:18 AM   #4
13B-RE front cover gaskets are metal and require no modifications
N390-10-502
They're not like head gaskets. They're stamped with a raised area in the center. They are also reuseable if you're careful.
Old 07-21-2010, 11:24 AM   #5
Nismo
400WHP or bust
Nismo's Avatar
N390-10-502
Good to know, I wish mine came with one!
Old 06-12-2010, 09:10 PM   #6
firzen
Good stuff. Subscribed.
Old 07-17-2010, 02:57 AM   #7
Stickied in archives...
Old 07-21-2010, 10:42 AM   #8
classicauto
crash auto?fix auto
classicauto's Avatar
I notice that it goes across the pesky o-ring area.
Does the gasket take the place of the oring there? Or does it just take the place of the oring "holder" and still requires the oring to be installed?
Old 07-21-2010, 10:42 PM   #9
The front cover-to-housing o-ring and nylon washer? Yes, you still need both of those. The gasket goes on AFTER you install the new ring/washer.
Old 08-06-2010, 02:07 PM   #10
diabolical1
I have radioactive semen
finally! a mod that i can use, at a time when i can use it.
