Old 05-23-2010, 12:32 AM   #1
Wiper switches
Is there anyone rebuilding these anymore? I'm a little tired of my toggle switch. At this point a functioning wiper switch would be a luxury.
Or how about the the relay numbers and that old write up?
Old 05-23-2010, 07:27 AM   #2
RotaryDiagnostics
Compression Tester Man
RotaryDiagnostics's Avatar
RotaryDiagnostics is on a distinguished road
http://www.rotorwiki.com/index.php/Wiper_Switch_Fix
RotaryDiagnostics is offline   Reply With Quote
Old 05-23-2010, 09:50 AM   #3
Perfect and awesome.
Thanks much
If anyone is wondering, the part numbers given are still good, the prices are a little outdated though
Old 05-28-2010, 09:27 PM   #4
MolotovMan
GTUs
MolotovMan is on a distinguished road
Thanks much
Pele over on RX7club rebuilds them. He does the Idiot clusters, wiper switches, and headlight switches.
I think for $75 each plus shipping.
I'll give you his info if you want it via PM.
MolotovMan is offline   Reply With Quote
Old 05-28-2010, 09:57 PM   #5
Sure, thanks man. I sent him a PM over on the ole' evil forum and never got a response. Figured he wasn't doing it anymore.
Old 06-10-2010, 09:30 PM   #6
MolotovMan
GTUs
He's been busy lately. I'll talk to him tomorrow if you're still interested.
Old 06-13-2010, 01:56 AM   #7
Definately interested. Wanted one a year ago but there always seems to be things more important that need my attention which is why right now I'd rather just pay for it than spend the time dicking around although I am about to order the relay
Old 06-11-2010, 05:58 AM   #8
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
Can he fix the "I work when I want to" clock issues with the idiot clusters?
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 06-14-2010, 07:07 AM   #9
FC Zach
FC Zach's Avatar
I have the same issue, what is the cause of this problem. Before it completely stopped working I assumed it was a bad connection at the harness so i removed it, checked for tight connection, reinstalled, and still had the same intermittent "I work when I want to" problem. I have become used to this problem and have never really cared to fix the issue but am sill curious about the cause of it
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 06-14-2010, 08:03 AM   #10
My5ABaby
My5ABaby's Avatar
The solder joints in the clock just go bad with time. I managed to fix mine by resoldering every point in the cluster.
Community Service Manual
RotorWiki
Old 06-15-2010, 01:00 PM   #11
I did that too, worked quite well... then I installed too much crap in my regular electronics area (gauges, etc). Now my clock continually reads 1:00 Sometimes it will work, but then something happens and it will reset to 1:00. I think it's a ground issue I caused, which is to be expected with the time constraint I was under when I installed the gages.
Old 06-11-2010, 09:23 AM   #12
Kentetsu
Kentetsu's Avatar
Is the problem with the wiper switch similar to the problem with 1st gen lighting switches? We have found that by shooting them full of Electrical Contact Cleaner (like 6 bucks from Autozone for a huge can) and working the switch back and forth for a bit, cleans the contacts up and gets them working again. No parts need to be removed to do this.
Might not apply to this issue, but I thought I'd throw it out there for you just in case.
Old 06-12-2010, 07:26 PM   #13
JerryLH3
JerryLH3's Avatar
JerryLH3 is on a distinguished road
The problem with the wiper switch is typically bad relays in the switch itself. Occasionally, cleaning the contacts seems to work, but a lot of people report only temporarily. The permanent fix seems to be desoldering out the old relays and soldering in new ones.
Jerry
1991 Mazda RX-7 Turbo - the current project/money pit
JerryLH3 is offline   Reply With Quote
Old 08-07-2010, 08:42 PM   #14
NYsNumba1Man
NYsNumba1Man's Avatar
NYsNumba1Man is on a distinguished road
How hard is it to resoder the wiper switch?
Originally Posted by Turbo II Rotor View Post
What if they bolted rotary engines to rotary engines to rotary engines to rotary engines to rotary engines to rotary to rotary engines to a rotary engine?
NYsNumba1Man is offline   Reply With Quote
Old 08-07-2010, 11:10 PM   #15
Nismo
400WHP or bust
Nismo's Avatar
You just resolder the 10pins or whatever for the connector, and it will fix it!
Not hard at all, fixed mine in just over anhour with removal/install time.
