Old 04-08-2010, 09:46 PM   #1
rotaryguy481
rotaryguy481 is on a distinguished road
Angry bad misfire t2 streetport help please!?!?!?!
I don't know what is going on with it the compression is good but it has a bad miss fire that I can't figure out at all from start then it dies and floods?????????
rotaryguy481 is offline   Reply With Quote
Old 04-08-2010, 10:18 PM   #2
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
stuck injector? fouled plugs? bad ground?
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 04-08-2010, 10:27 PM   #3
rotaryguy481
Would pre mixing to much oil clog the injectors
Old 04-08-2010, 10:49 PM   #4
How much is too much?
Got pics of the plugs?
Old 04-08-2010, 11:05 PM   #5
reaper
2slow4u
reaper's Avatar
reaper is on a distinguished road
agreed, pics of plug would help.
my hoarse is amazing
sincityrotary.com
a place for las vegas rotary enthusiasts
reaper is offline   Reply With Quote
Old 04-08-2010, 11:27 PM   #6
rotaryguy481
I will post some up tomorrow and they got a lot of black gunk on them pretty bad and its only got alil over 2000 miles on the motor
Old 04-09-2010, 12:15 AM   #7
Justen
In Too Deep
Justen's Avatar
Justen is on a distinguished road
I would make a code reader if I were you. Turned out to be the best 5 bucks i ever spent.
I had a similar problem, just rebuilt my turboII motor, streetport... It started up but flooded and backfired like a bitch.
Mine threw a code saying there was a problem with my thermosensor (on the back of the water pump). When the sensors bad or the circuit is cut, the ecu dumps fuel into the motor as a "fail-safe" so you don't detonate, no matter what your temps actually are. I fixed that, and my car ran better than it did before the rebuild, streetport, and emissions removal... go figure
It could be that, your throttle position sensor, bad injectors, or something else.
I can't pinpoint it, but a code-reader could definitely narrow down the possibilities for ya
1990 TII, fresh rebuild
Atkins rebuild kit, RA apex seals
Med. Streetport, TB mod, rebuilt turbo, ported wastegate, GodSpeed FMIC
RacingBeat Turbo-back straight exhaust, Bonez test pipe, emissions/nest removed
hks intake, Walbro, Profec B spec-2
Justen is offline   Reply With Quote
Old 04-09-2010, 05:23 AM   #8
Are these the original spark plugs you used on break-in?
If so, then a lot of the crap is from the blow-by from the engine breaking in.
I recommend swapping to a new set of plugs after the initial break-in period if the break-in plugs are no good.
Old 04-09-2010, 10:10 AM   #9
rotaryguy481
How do I make the code reader for it lol I think I know where to plug it in at but just incase where it be
