Old 02-26-2010, 05:46 PM   #1
brycerxer
brycerxer's Avatar
brycerxer is on a distinguished road
Pulsation Dampener (PD) Replacement
I've been doing a whole lot of reading and searching (even in the FSM) for info on the replacement of the PD on the primary fuel rail. There is a whole lot of discussion about banjo bolts etc, but nothing about the actual replacement. Being a novice mechanic at best, here's what I'd like to know: 1) Do I need to remove any other parts to do it? It looks like I just loosen it with an open ended wrench and replace it -is it that simple? 2) Can I just tighten that little phillips head screw that comes loose and leaks for a temporary fix in order to drive it twelve miles home?
Do any of you have experience with this? Any help would be much appreciated.
'85 RX-7 GSL-SE Current Driver
'85 RX-7 GS Current project
'84 RX-7 Parts car-SOLD
'91 RX-7 VERT SOLD
brycerxer is offline   Reply With Quote
Old 02-26-2010, 05:57 PM   #2
brycerxer
brycerxer's Avatar
Here's a quick backstory: I've had the car for over a year now and just recently covered some repairs that made me feel more comfortable driving it more often (coolant flush, new T-stat, new idler arm bushing). I drove it 24 miles to work and back Monday and Tuesday then to work on Wednesday -no problems. At work I drove a couple blocks to get something to eat, noticed a strong smell of fuel, shut it off, popped the hood and sure enough there was fuel leaking from the area of the intake/fuel rail. Enough to begin pooling on top of the engine a bit and dripping on the ground. I know I'm lucky I didn't have an engine fire. So I got online and started searching and everything pointed to the PD, so I ordered one from Mazdatrix (deciding against the banjo bolt fix), but I don't expect it till next week. (I'm not really even 100% sure that the leak is at the PD). I really don't want to leave my car parked at work over the weekend, but don't really want to pay to have it towed either. So, that's why I'm wondering if I could tighten that little phillips head screw and drive it 12 miles home. Also, I want to know what is involved in the replacement when the part does come in, so I would know if it could be done in the parking lot at work fairly easily. Again, thanks for any info/advice you could offer.
'91 RX-7 VERT SOLD
Old 03-01-2010, 10:27 AM   #3
Rogue_Wulff
Non Member
Personally, I wouldn't drive any vehicle with a known fuel leak, especially on top of the engine, even around the block.
I can't speak as to the replacement proceedure, as my SE was converted to carb before I got it.
Old 03-01-2010, 11:56 AM   #4
j_tso
j_tso is on a distinguished road
You're gonna have to remove the upper intake manifold, which means disconnecting everything to it and the throttle body. The PD itself may be pretty stuck to the fuel rail, so be prepared to yell at it. And please be careful when taking off the fuel rail, there's still gonna be some pressure in the fuel lines.
j_tso is offline   Reply With Quote
Old 03-01-2010, 03:47 PM   #5
Ender
rotors excite me
Ender's Avatar
Try not to crank too hard on the rails, you'll really be screwed if you bend one or God forbid bust a bolt off on top of the block, or an injector... I'd remove the whole rail and take the PD off with it out of the car. Make sure you use proper sized FUEL line clamps, the ones that don't have a bunch of little slits for the screw to tighten/loosen. I had an engine fire because I used the wrong type and it didn't seal right.
I've used a banjo bolt for at least a year instead of the PD and I've had no apparent problems... Also, as soon as the upper intake manifold is off put clean rags in the ports so you don't drop parts down them. Then you'd really be pissed off.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 03-16-2010, 09:01 AM   #6
kenn_chan
kenn_chan is on a distinguished road
Subaru WRX any bug eye, blob eye, hawk eye with the Ej20 turbo has an inline pulsation dampner that you could easily use on any fuel system....this is good if you want to keep a PD but are using aftermarket fuel rails etc.
kenn
kenn_chan is offline   Reply With Quote
Old 03-22-2010, 11:34 AM   #7
rx4ur7
Rotary since 1972
rx4ur7's Avatar
You can put the screw back in. I have done it on many. Most have gone years without a problem. Replace the oring if you can. Also put a drop of locktite on the threads.
It can be replaced without removing manifold. Although somewhat easier if it is moved.
