Old 12-22-2009, 03:11 AM   #1
iloverotary
iloverotary is on a distinguished road
1986 S4 RX7 NA with JDM S4 TII SWAP WIRING??
Its a JDM S4 TII motor with original motor harness in a S4 NA chassis..
I was wondering if anyone knows the rewiring procedures?
I been researching for hours and cant find anything.
iloverotary is offline   Reply With Quote
Old 12-22-2009, 11:22 AM   #2
So you have the engine, harness, ECU, AFM, and boost sensor?
If so, you just swap over all those items. Should be plug and play.
At least it is with S5.
Old 12-22-2009, 03:02 PM   #3
iloverotary
yeah i have all of that..
Old 12-22-2009, 01:58 PM   #4
The JDM engine wiring harness will not fit, cause it's too short.
Old 12-22-2009, 02:03 PM   #5
Damn, I forgot about the JDM part.
You can either rework your S4 NA harness to work, or try your luck at a used, most likely crusty, US Spec S4 TII harness.
*This is a useful reply to a thread.
Old 12-22-2009, 05:43 PM   #6
Did you read these links:
http://rotarycarclub.com/rotary_foru...read.php?t=285
http://www.rotaryresurrection.com/2n...to_turbo2.html
Other than the basic, swap it all in and see what happens, we'd probably need specifics as to whats going wrong. If you have all the required parts (including the proper length USDM harness) it should be fairly straight forward since you're keeping it S4.
Old 12-23-2009, 02:05 PM   #7
iloverotary
i found this thread in another forums http://www.rx7club.com/showthread.php?t=749041
