need PCV help
So in my effort to remove my carb I broke the plastic bit on what i would call the PCV
my question is 2 part 1 does anyone have one laying around they want to part with. 2 seems I can hopefully find a hose barb with the right thread pitch and using a hose then a generic PCV vale then a hose back to the carb base make one up. advice, comments. anyone thanks
Spokane,WA. Directly above the center of the earth |
Professional Stick Poker
pics? might have.
ok here you go
Well i found that its just a standard pipe thread like 3/4 so i might try to work something out using the old part. stiil if anyone has any advice or a spare...... ![]() ![]()
Spokane,WA. Directly above the center of the earth Last edited by 79rx7; 12-02-2012 at 04:40 PM. |
Yep, have one if you want it.
On it's way. Plastic looks like it's getting brittle so be careful with this one.
#8 | |
The check as they say, is in the mail. or in this case the cash is in the mail thanks for sending it out in the interim i cut my plastic off and now know how to effect a very nice repair for very little coin.
#9 |
Glad to help. Happy Mmmmmmotoring!
