Old 12-15-2010, 12:59 AM   #1
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
OEM Wiring
Short of buying a new wiring harness, whether is be engine, battery whatever... is there anywhere you guys know that sells OEM color coded wires, say you want to move a fuse box, or replace every wire in the harness and keep the factory colors for easier Identification later, is there a place that sells them....
just curious, thinking for suture reference etc..
Thanks
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 12-23-2010, 10:50 AM   #2
RXtacy
RXtacy's Avatar
You can order a large variety of color combinations here.
http://www.prowireusa.com/departments.asp?dept=74
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 02-19-2011, 06:04 PM   #3
Prodigy
Prodigy's Avatar
(I'm really a huge noob when its comes to wiring, hence the questions)
With wire from prowireusa. do you guys (who ever has done it) run all the same color of wire, or do you try to switch it up a bit... i'm curious as I would like to replace a few wires in my engine harness (maybe add a few as well) and was wondering what is the best way/solution...
Originally Posted by Sideo View Post
thanks for the link! im working on wire tuck only done the ridiculously easy passenger side so far.
Did you put it all below the headlight...? I would love to do this, just want a little guidance/advice :P
J.
Old 02-20-2011, 11:37 AM   #4
J.
When I did this on my FC I was lucky enough to have access to a second front harness. I cut the wires out of the spare harness to keep the colors consistant. Short of doing this, Prowireusa.com is the best place that I have found to get wires.
Adding spare wires is a good idea if you're planning on changing shit around. For example, in my FC, I have a battery cut off switch. But I also don't like constantly resetting my radio presets, I have an alarm, power window roll-up relay etc etc etc that would be useless if the battery was shut off. So with access to the spare harness, I wires a few of the circuits in the stock fuse block strait to a breaker off the battery before the cut off switch so I can turn the battery off, get out of my car, hit the alarm arm, the windows roll up, the parking lights flash, the horn honks, my radio keeps it presets and I can unlock the doors when I get back. This required alot of thought and planning. Planning is key to wiring.
Using the same color as the factory is a great idea, makes trouble shooting easier. It's pretty easy to look into a harness and see which wires are factory and which are not. What I do is print out the appropriote FSM wiring shematics and makes notes to the changes that I have made.
Old 02-14-2011, 12:22 AM   #5
Sideo
Sideo is on a distinguished road
thanks for the link! im working on wire tuck only done the rediculously easy passenger side so far.
Sideo is offline   Reply With Quote
Old 02-15-2011, 01:41 AM   #6
^Looks good! I would love to tuck all the wires but I didn't think it was possible.
Old 02-20-2011, 03:23 AM   #7
Monkman33
Still Building my FD
I too would love to see what others have done in the "wire-tuck" side of things. my generic search for "wire tuck" didn't pull up much, and the fact that I am on a new laptop here at MOS school also means I don't have any of my old bookmarks.
