Old 09-10-2010, 04:39 PM   #1
sen2two
KTEC
sen2two's Avatar
S5 stock maniold, external dump
Here's a sneak peak at this for now. I have been seeing here, and other places, where people want to fix the whole boost creep, and boost dropping off before peak RPM. One way is to get an upgraded Garrett internal gate that is very similar to our stock wastegates, and port the wastegate areas on the turbine housing. This works well for a lightly modded car, but some still need more. Especially if the motor is ported, running higher compression, or runnning a hybrid turbo.
Now it has been done a few times on the much larger S4 manifold. But with the very small compact S5 manifold, and divided runners, making an external dump far more complicated. A few people have also kept the stock wastegate area but separated the down pipe area and wastegate area for an external dump. This still poses a problem with releasing enough exhaust pressure through the holes in the turbine housing. Making creep and drop off less noticeable, but not getting rid of it.
Here is what i am going to do to fix the problem. A one inch hole in each runner, meeting at one point with a 38mm external wastegate.
Pics do much better than words.
(I'll update after it's all welded up and finished, I got side tracked with another project and didn't get t finish)
Holes were done with a bridgeport mill. Now I know not many people here will have access to a machine like that. but its not hard to drill a hole with a hand drill and port it out with a die grinder.
Got some pipe and turned it down slightly in a lathe to fit very snuggly in the holes. I'm all about tight fits,
Cut some pipe and mocked it up. A little trimming and grinding, and this will all fit nicely. There's actually a pretty good amount of room below the manifold to come up with your own design. Just take some measurements and get to cutting!
what I have:
What I had:
Old 09-10-2010, 06:16 PM   #2
soldave
soldave's Avatar
soldave is on a distinguished road
Is a 38mm wastegate gonna be big enough? I'm going for a 50mm to be on the safe side.
Big in Japan: soldave.ismysite.co.uk
soldave is offline   Reply With Quote
Old 09-10-2010, 09:00 PM   #3
sen2two
KTEC
sen2two's Avatar
38mm is plenty large enough. My motor is completely factory. Hasn't even been rebuilt yet... Most people port the stock wastegate to 35mm.
I am not a fan of overly large wastegates. Here's why... In theory of course, but I would rather be safe than sorry in this case.
whether you have a large wastegate or small wastegate, they still open at the same speed. And that speed is quick. When you hit your set PSI and your overly large wastegate opens, it releases a large amount of exhaust pressure quickly. Most of the time TOO quickly. Causing exhaust pressure drop and possibly a drop in boost momentarily slamming it shut again only to open quickly again. You might not notice this, but I'm sure the motor does.
what I have:
What I had:
Old 09-10-2010, 11:21 PM   #4
Lemme start off by saying that this is pretty damn cool. Good job on the work so far.
Instead of guessing, I would datalog it. MAP and EMAP as well as WG duty. If you're running any sort of ems or electronic boost controler, you sould be able to tune it out.
Old 09-10-2010, 11:33 PM   #5
need RX7
Clean S4 Nutswinger
need RX7's Avatar
very interesting.
Old 09-11-2010, 12:24 AM   #6
You've just destroying the whole reason why Mazda redid the turbo exhaust manifold and turbine section.
Seriously, you guys need to leave alone these "rare" parts and go mess with S4 stuff.
Old 09-11-2010, 02:45 AM   #7
there is no way to get better flow out of the S5 manifold?
Old 09-11-2010, 03:33 AM   #8
jerd_hambone
Senior Member/Lounge Rat
jerd_hambone's Avatar
Hey now, just because Mazda spent a million dollars redesigning something, doesn't mean it is working at it's peak. He's not trying to mess with what Mazda did exactly, he's more on the lines of trying to make his car as reliable as possible. One good boost spike can do all sorts of damage.
Relax there ol' buddy!
1986 Luxury Package
1987 Luxury Package (sold)
1988 SE (sold)
1989 GTU (sold)
1990 GTU (sold)
jerd_hambone is offline   Reply With Quote
Old 09-10-2010, 09:08 PM   #9
have you done any amount of porting to maximize the exhaust flow in the stock manifold?
Old 09-10-2010, 09:39 PM   #10
sen2two
KTEC
sen2two's Avatar
Started on it, But havnt finished it just yet. I'll finish the port work after i finish the wastegate job.
I will be doing some port/flow work the the rear turbine housing also.
This will not go onto the car just yet though. I want to hit 12's on the untouched factory turbo first. I'm about ready for that though. So hopefully this will go on soon enough.
what I have:
What I had:
Old 09-10-2010, 10:17 PM   #11
keep it up man, I can't wait see what results/improvements you achieve.
Old 09-11-2010, 02:37 AM   #12
soldave
soldave's Avatar
What's rare in what he's done?
Old 09-12-2010, 03:12 AM   #13
sen2two
KTEC
sen2two's Avatar
Or maybe I post thing's up from time to time to impress you, only to be shot down time and time again. You have broken my hear one to many times...
Seriously man, is there any thing you do like, that hasnt come from you?
what I have:
What I had:
Old 09-12-2010, 05:16 AM   #14
You must be one of those too stubborn to listen to other people's criticism.
Seriously...
You plan is a royal waste of time and money for most people.
Please go read Corky Bell's "Maximum Boost".
Your new wastegate pipe entries are very inefficient - 90-degrees perpendicular to the actual exhaust gas flow.
(If you had gone with the S4 turbo exhaust manifold, there is already an angle built into it, and you would've had a more efficient and easier time doing this same procedure.)
Corky Bell also talks about how keeping exhaust flow between the two turbine passages can be advantageous.
If you think I'm just spewing sh*t out of my ass, then so be it.
If you think I have some personal beef with you, then so be it.
(Seriously, it's nothing personal.)
I'm trying to correct some of your misconceptions of what you're trying to do and warn others of the shortcomings.
If you don't have the openmindedness (is that a word?) to see that, well, then I wish you good luck with your project...
Old 09-12-2010, 03:41 AM   #15
I always like to tell people to "Read between the lines...listen to what is being said, not how it's being said." Ted comes off rather harshly some of the time but you know he means well even if it doesn't read like that. He doesn't believe the external WG is MORE effective than a properly posted twin-scroll system on our setup and therefore this mod seems redundant to him, especially on the S5.
I would take all the input you've received so far, see what benefits you can achieve and then post your findings...Ted knows what's up when it comes to these cars, their components and sometimes it takes real numbers to change his mind. As you continue to research these mods you'll be able to show what benefits you have achieved or perhaps you'll reinforce what ted has been saying all along. You won't really know/satisfy your curiosity until you finish.
