Old 04-08-2010, 06:54 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Question regarding pressure sensor restricter 'pill'
I'm about to reinstall the vacuum orifice in my pressure sensor's vacuum line. From what I've read, it should be about 1" from the end of the vacuum line on the manifold end.
However, I've noticed on mine that it has a large hole on one side and a small one on the other. Does it have to go in a certain way? I assume it doesn't matter, but I just want to double check.
Old 04-09-2010, 10:27 PM   #2
T24TODD
RE_P ROTORs
T24TODD's Avatar
T24TODD is on a distinguished road
Nope either should work. I did mine large end facing manifold small to pressure sensor... Alot of people dont even use them and I never used one for 2 years after my build with no problems whatsoever. No change with it in so 3 bucks wasted but makes my brain feel better theres still a little left to my block
T24TODD is offline   Reply With Quote
