Old 06-17-2009, 01:46 AM   #1
joff
joff is on a distinguished road
Walbro fuel pump disassembly
Arizona Rotary Rockets donated a walbro fuel pump recently to me for destructive disassembly. The pump was out of a car that had experienced fuel system glitches. There actually didn't seem to be anything wrong with the pump, but Glen told me it will never go in a AZRR car because it can't be known for sure due to the circumstances in which it was replaced.
Anyway, some background on the pump before I post pictures.
The pump is covered under US patent #4500270 and the number is stamped right on the metal cover. http://www.freepatentsonline.com/4500270.pdf for full text of the patent. The patent includes many technical illustrations and detailed descriptions of the operation of the pump. The patent was published in 1985 and is now expired and free.
Abstract:
"A positive displacement fuel pump utilizing an in-line pump and armature with a flexible drive connection and spring-pressed backing plate for the pump and short cantilever mount shaft for the pump rotor."
This design is more similar to our oil pump (positive displacement) than our water pump (centrifugal). Or -- another way to look at it -- more similar to a twin-screw supercharger than a turbocharger.
There is a spring loaded one-way check valve in the plastic fuel outlet barb to keep pressure in the fuel system for faster starts. The check valve includes a very small spring and rubber gasket.
There is also a pressure relief valve that only allows maximum pressure to avoid hydro-locking the positive displacement gear pump. The pressure relief valve is a spring and rubber ball. The pump vents excess fuel to a port on the top of the pump.
The motor is a regular DC motor with spring loaded carbon brushes and commutator.
Size comparison with cell phone:
Bottom plastic piece removed -- gear rotor showing through opening
Metal cover removed
Top plastic piece and rubber o-ring
Top plastic piece pulled apart, showing brushes and brush springs
joff is offline   Reply With Quote
Old 06-17-2009, 01:57 AM   #2
joff
Flexible fiberglass like diaphragm (theres another one inside the motor housing)
Top plastic piece and misc parts in background. Check valve is visible on outlet.
Cut out the check valve to see what it looks like -- just a spring and piece of rubber.
Cut out the pressure relief valve. Bigger spring and rubber ball.
Motor connected to the gear-rotor.
Old 06-17-2009, 02:12 AM   #3
joff
Little gear rotor pump assembly is pretty neat. Made of stainless steel.
Look what I found in a corner when I was at AZRR -- 2 20B's waiting to be rebuilt and ported!
Saw this on their shelves too. Somebody's having them build a drag car. Yes, that turbo is actually bigger than the housing!
Old 06-17-2009, 03:01 AM   #4
joff
Compared to a turbine (westco) pump like the Bosch 044 this pump design will inevitably produce more small pressure fluctuations due to the positive displacement design. It also has a few more failure points with the fiberglass diaphragm and pressure relief valve and integrated check valve.
The motor is a brushed motor, which means it has a finite lifetime and inevitably will wear out. The gear rotor has metal/metal contact and will also probably wear out (or seize). The electric motor has no ball bearings -- it is held upright by raw plastic/metal contacting "pegs".
Here's the patent on the westco pump:
http://www.freepatentsonline.com/3233551.pdf
It is my understanding that the Bosch pumps use this basic design but packaged in a more appropriate way for a fuel tank. Reading the more recent NipponDenso patents and Bosch patents it seems only very minor improvements have been made from the 1966 design. (Mostly regarding pump channel and the water wheel aerodynamics)
Old 06-17-2009, 04:46 AM   #5
Just to play devil's advocate...
Do you know what the predicted life cycles of the fuel pumps are?
I mean it's one thing to argue certain parts are inferior (that's obvious), but what if it was perfected fine give certain operatin parameters?
Are you qualified to make those conclusions?
Also, if it isn't obvious, there are lots of Chinese fakes out there.
Can you confirm if the unit you've got is a true Made-In-USA unit?
Old 06-17-2009, 10:41 AM   #6
joff
Its not my intention to argue whether or not this pump is inferior to anything else. I've tried to only present facts.
I am an electrical engineer and not making any conclusions. Brushed motors are known throughout the industry as not as long lasting as brushless. Wikipedia can even confirm this. At this point, I don't even know if other pumps use brushed or brushless motors.
This pump is not bad. Some positive to balance out what may have unintentionally been seen as negative:
*) The brushes seem long -- there is lots of spare length in the upper pump housing. Not certain how much life this pump has seen and what length the brushes started so I personally could not predict lifetime. If I dissected a brand new pump, I could measure brush lengths and give a percent used-up on this one.
*) The diaphragm's seem made of fiberglass. These material is flexible, yet very sturdy.
*) The patent is newer.
Its not obvious to me there a lots of Chinese fakes, I only have this one to compare. I try to do my own research on things rather than follow hearsay.
As to whether or not this is a true made-in-usa unit, please take a look at this pic:
Old 06-17-2009, 01:36 PM   #7
glenrx7
glenrx7 is on a distinguished road
Attachment 5700
Attachment 5698
Attachment 5699
By the way That turbo is a holset and it is going on the azrr drag r100.
glenrx7 is offline   Reply With Quote
Old 06-18-2009, 12:46 PM   #8
joff
Another interesting thing to point out is this particular pump's gear rotor is not exactly the same as the patent diagrams. If you read whats actually in the "claims" section, there is no mention of number of teeth or shape of teeth which is something where they differ. There are several other slight variances between patent and actual implementation that could possibly be the result of whats done for different size pumps and/or subtle improvements or reductions in cost through the years. It could also be places where a generic and brand-name walbro could differ.
It seems the "Walbro" name may be on a similar track as the "Westco" name. Both used to be a company name, but now almost more appropriately refer to a type of pump design, that without patent protection, is easy for just about anybody to manufacture.
Here's a link to a Westco style, or "Turbine" pump -- its not a fuel pump, but the PDF has an informative breakdown of the guts of what makes it work.
http://www.mepcollc.com/1484.pdf
Old 06-22-2009, 11:17 AM   #9
joff
I got a response from Walbro corporate on the authenticity of this pump. Turns out Glen was right and this pump is genuine.
Originally Posted by Walbro
From what engineering can tell from the photos, it appears to be ours.
There are many off-shore counterfeiters. They will also copy “made in USA”, our model numbers, even our manufacturing date code information not knowing what it is. From the outside, it is sometimes very difficult to tell ours from a counterfeit.
For a reliable source, you can contact our national distributor, The V E Petersen Company @ 800-537-6212 or online through Cyberspace Automotive Performance at www.Fuel-Pumps.net.
Hope this helps you and thanks for asking.
Regards,
Diana Hutchinson
TI Automotive Aftermarket
630 Columbia Street
Caro, MI 48723
dhutchinson@us.tiauto.com
