Old 02-11-2008, 03:41 PM   #1
Comparison between 13B REW, 13B- RE Cosmo, and 20B UIM
Here are my UIM from 13B-REW, 13B-RE Cosmo, and 20B Cosmo.
Enjoy!!
13B REW and 13B- RE top view
13B REW and 13B-RE Bottom side (REW is customized)
Comparison in length.. using the RB swaybrace as a straight edge..
Bottom
Old 02-11-2008, 03:42 PM   #2
Top
13B-REW, 13B-RE, and 20B
Old 02-11-2008, 03:42 PM   #3
13B-RE and 20B comparison.. They are the same in length..
Old 02-11-2008, 03:46 PM   #4
Modified 13B-REW
normal 13B-RE
Old 02-11-2008, 03:48 PM   #5
Here are the TBs
20B TB vs 13B-REW
Old 02-28-2008, 04:41 PM   #6
cabaynes
cabaynes's Avatar
cabaynes is on a distinguished road
Nice pics Phil, although a bit dark
You said you plan on using the RE manifold on your REW motor?
Charlie | cabaynes.com | '93 R1 CYM (x2)
cabaynes is offline   Reply With Quote
Old 02-28-2008, 11:36 PM   #7
McVicker
McVicker's Avatar
McVicker is on a distinguished road
are there any proven advantages to the Cosmo RE intake manifold?
Scrubs McBubs!
SakeBomb garage.com
McVicker is offline   Reply With Quote
Old 02-29-2008, 01:50 AM   #8
TRISPEEDFD3S
TRISPEEDFD3S's Avatar
TRISPEEDFD3S is on a distinguished road
Hmore power in the high end, but you lose some torque in the lows I believe.
My Cardomain!
http://www.cardomain.com/ride/2179693
TRISPEEDFD3S is offline   Reply With Quote
Old 02-29-2008, 12:25 PM   #9
IR Performance
I believe it is the opposite. The 20b and 13bre were both found in the larger luxury car the cosmo. The motor was more tuned for torque in that application. It had larger intake ports and runners, but smaller exhaust ports. They do flow better than the 13brew manifolds however.
Old 02-29-2008, 12:53 PM   #10
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
Interesting, I’ve never really thought about it before, but your two responses got me thinking. I’ve always “heard” the RE intake manifold increased low end torque, but that does go against conventional wisdom when compared to the REW intake. Generally increasing the intake runner length increases low end torque. Unfortunately they are not a direct comparison as the RE intake does have larger primary runners and the parabolic chamber. I guess there is no way of knowing for sure without testing.
I nominate Phil as the guinea pig to test it out
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
Old 02-29-2008, 08:30 PM   #11
charlies7
one broke moderator
charlies7's Avatar
charlies7 is on a distinguished road
I have a set of RE manifolds waiting to be tested Dan..This summer I will dyno using both and let everyone know. Too bad I have to run two different fuel systems..At least the secondary rail
Who knows though maybe Phil will beat me to the task. However I am expecting more top-end power and a better power curve..turbo undecided
Dan
charlies7 is offline   Reply With Quote
Old 02-29-2008, 01:59 PM   #12
IR Performance
I don't think the runners are on the RE are longer. The manifold does have more capacity however.
Old 02-29-2008, 11:51 PM   #13
cewrx7r1
The Judge
I do not believe runner lenght has much affect on turbo cars as they do not have to rely on intake dynamics to make power. They are forced fed.
Old 03-01-2008, 01:52 AM   #14
McVicker
McVicker's Avatar
I'd be interested to see someone who has access to a dyno, test one manifold, uninstall it and put the other on and test again in the same day to get an accurate comparison.
-Dan
Scrubs McBubs!
SakeBomb garage.com
Old 03-01-2008, 07:58 AM   #15
You can't really run cosmo lim on the REW short block without port matching. Ports on the REWs are about 20% smaller.. I'll post some pics later..
So, that being said.. in order to take advantage of RE LIM you need to port match the LIM to REW.
