Old 08-31-2009, 09:49 PM   #1
RX8 Dyno
So I finally got some base line numbers on the 8 this past Sat at KDR. Went up there to meet Brian and his FC again and to hang out w/ Dave and see what the shop was all about.
I was pleased with the numbers for a stock RX8 as compared to what I've seen throughout the interweb.
Specs:
2004 w/ 52K on the clock
K&N Drop in
Redline Rear Diff fluid
38psi in all tires
Racing beat wires and brand new NGK plugs
Future plans are to lean out that nasty fuel dump over 7k, add a new clutch (started to slip a little at 7K in 4th), lighter flywheel, headers, AP tuner and some new suspension.
My goal is 200 corrected whp... I think I can get it.
Old 08-31-2009, 10:32 PM   #2
More shots from the dyno, nothing special
Old 08-31-2009, 11:30 PM   #3
I was hoping you would make this thread. She handled the abuse like a champ, esp that long 18 sec pull. I think you can get there Bill. What did Dave say about gains by leaning out that pig rich @>7k? I think most of the gains can be had there. Does the software allow for any ignition adjustments?
Old 09-01-2009, 09:24 AM   #4
reddozen
Gold Wheels FTW
reddozen's Avatar
Just making sure, you did pull the ABS fuse right?
From what I've read it's important to do so in order to get a proper dyno read.
200 should be doable without engine mods. I can't wait to get my bridge ported rene back and see what numbers it will put down before I turbo it...
My Cars:
1974 RX4 Coupe
1991 FC3S RX7 - Sold
Old 09-01-2009, 05:41 PM   #5
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
200 with tuning only is doable.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 09-01-2009, 07:48 PM   #6
We didnt pull the ABS fuse, but disabled the ABS/DSC system all together. She was accurate alright, lol.
Dave definitely thinks leaning those curves out will pick up a few extra... like you said, the gains will be all up top. He didnt really give numbers, but probably looking at 4 to 5 at around 8000 and up at least... maybe more. I'll need to get an AP tuner and find out. I'm thinking of getting one before any other mods now actually (other than some planned aero and suspension mods).
Those 18 second pulls were great! I think it did the car good, I took her to 95mph today on a quick run and it pulled better than it has before, but than again - I did just do the RB wires and new plugs too...
Old 11-05-2009, 02:25 PM   #7
MIKES'8
MIKES'8 is on a distinguished road
i pulled 211 rwhp with these mods no tune.
mods:k&n intake, custom header, turbo xs headerback exhaust, mazsport coils, mazsport fan mod, rb air duct, rb flywheel, throttle body pp ,tb bypass, exedy stage 2 racing clutch, ap pulley,sprint springs, mazdaspeed front strut tower bar and rear trunk bar,custom oil catch can,af sts, shine front lip,evor rear cf trunk spoiler, rx8strakes window visors, mazda piano blk side pillars, piano blk eyelids,rota d2 18x8 and 18x9 +5 et all
im trying to hit the drag strip soon and break 13s with some street slicks, keep you guys updated.
2005 MAZDA RX8-THE WEEKEND WARRIOR
2008 MAZDA CX7-THE FAMILY RIDE
1994 MAZDA MIATA-THE CLASSIC(36K ORG MILES)
1992 MAZDA 929-THE VIP PROJECT
1989 MAZDA MX6-THE DAILY
MIKES'8 is offline   Reply With Quote
Old 11-05-2009, 02:30 PM   #8
MIKES'8
your biggest gain will come from your header and exhaust setup.
Old 11-13-2009, 11:24 PM   #9
ganseg
ganseg is on a distinguished road
I want to have my car dyno'd (stock 2004 with 35k). WOndering if one type of dyno is better than another for a low torque, high redline car. I am in the Minneapolis area and i think there are two or three choices of shops here.
ganseg is offline   Reply With Quote
Old 11-14-2009, 09:53 AM   #10
Typically the dynojets will yield slightly higher numbers than a mustang dyno. Some people say tuning on a mustang dyno is better and more accurate.
The more important factor IMHO is that you use the same dyno throughout the build. This way you know your gains are accurate even if the equipment isnt and your not introducing a different variable into your tuning.
Also, find a good shop. I have dealt with some pretty bad dyno shops and it took a while to find one I liked and trusted.
Old 11-14-2009, 10:01 AM   #11
ganseg
Would anyone say the RX-8 poses any special requirements for a dyno? THe reason I ask is because I would think the rotary would have a harder time spinning up the drum (low torque) and then showing its best at the high RPM when the HP comes on. I have also noted bigger than expected differences between stock engines - peaking at 8000 rpm vs still pulling when the throttle is cut.
I am hoping to dyno it before mods and then dyno each change - probably engine management first.
Old 12-06-2009, 02:07 AM   #12
reaper
2slow4u
reaper's Avatar
reaper is on a distinguished road
i'm curiouse to see what mine would do now lol. any estimates?
05 6spd, snorkle mod, defogged airbox,hks high power and esmeril coils, mazdatrix plug wires
my hoarse is amazing
sincityrotary.com
a place for las vegas rotary enthusiasts
reaper is offline   Reply With Quote
Old 11-14-2009, 10:08 AM   #13
Rotary cars may not have a lot of torque but they'll spin the drums just fine. The operator of the dyno will need to disengage the ABS/DSC system though as that can fight the drums during operation.
Old 11-14-2009, 10:20 AM   #14
ganseg
I have a 2004 base model, so I don't think I need to disable anything?
Old 11-14-2009, 06:07 PM   #15
reddozen
Gold Wheels FTW
reddozen's Avatar
You'll still need to disable the ABS as far as I know. It's just as easy as pulling a fuse under the hood though... nothing hard.
My Cars:
1974 RX4 Coupe
