MG rocket
Beneficial gauges in a 13B
During the making of a new alloy console that will house additional gauges, I got to thinking... what aftermarket gauges are really of any benefit to the driver and not just cosmetic bling?
With Oil temp, Water temp, Transmission temp, Fuel pressure, Oil pressure, Battery condition, Amp meter etc available, what do other 13b owners believe are of true benefit to the driver and not just dash board bling? I am not after a Boeing cockpit look, just want to add gauges that useful to a Extend Port 13B that is used for "spirited" road use. |
#2 | |
Don Mega
I say rev counter #1 Water temp #2 Warning lights for oil pressure #3 (blinks when under set minimum) off when at proper pressure works great! AFR instrument #4 is a cool beneficial thing to have when tweaking your jetting in the carby and they are inexpensive now. BIG REV COUNTER ! in the middle rotary style, all else is not really that important lol.
#3 | |
I've been Wankeled!
![]() Rx-4 gauges.jpg Seriously though, I completely agree with rice. Warning lights and buzzers go a long way. They get your attention quicker than a gauge. Definitely get an AFR meter though. It is a very valuable tool for tuning. Takes all the guess work out of it.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place 1974 Rx-4 all original 27,000 miles 1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place |
1) boost
2) EGT 2nd tier: water temp, oil temp, oil pressure 3rd tier: fuel pressure, system voltage, fuel pump voltage Everything else is fluff. AFR gauge is a royal waste of time IMO. -Ted |
#5 | |
Rep Power: 20 ![]() |
1) Boost 2) EGT (one for each rotor) 3) Fuel pressue 4) RPM 5) Speedo 6) AFR (helps when tunning and troubleshooting) 7) Voltages (fuel pressure, etc)
MG rocket
Thank you for your comments...
I appreciate your comments.
Now for a "novice" question... What is EGT? Mal |
The fan hit the shit!
For me this is what i have and feel being highly beneficial
1: Boost(of course not with a n/a car) 2: Wideband AFR. 3: Water temp(taken from the backside of wp housing. most accurate) 4: Oil pressure 5: Oil temp 6: Egt (taken pre-turbo) 7: Fuel pressure 8: Voltage Also if your going to buy gauges save yourself the hassle and just bite the bullet and buy good quaility electric gauges. Zack. |
#9 |
Where's TTT to say we should all watch EMAP.
#10 |
lol, that will actually be my next gauge as soon as i get a few things sorted out with the transducer i have.
zack |
