Old 06-21-2010, 09:31 PM   #1
firstrotary84
firstrotary84 is on a distinguished road
plugs a little white, when i pulled them out?
i have an 84 gsl se 1.3 resi, i pulled my plugs and the are a little white. how do you add more fuel with the fuel injection, and which plugs should i be using?or am i having a different problem all together? please help me out! thanks
firstrotary84 is offline   Reply With Quote
Old 07-12-2010, 09:07 PM   #2
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Depending on the whiteness you could be fine. As long as your exhaust temps are OK and you are not over heating I wouldn't be too concerned.
You can richen it with the mixture control. Located just aft of the air filter box. It is a recessed screw in a brown case. There were two curved arrows also showing an L and R. It does not take much to make a drastic change. If you really have to do it in slot sized increments.
In lieu of that you could add a little Redline Two stroke race oil also. That would richen it up.
