Old 04-25-2010, 03:28 PM   #1
Akagis_White_Comet
Comealong busts your nuts
Akagis_White_Comet is on a distinguished road
FS S4 N/A parts
I have a decent cache of S4 N/A parts, so it's time to clean house. All parts are S4 N/A unless otherwise noted and in Lancaster too. I need this stuff gone. All prices are OBO too. Will ship items too, at buyer's expense using whatever method is cheapest/easiest/most reliable.
S4 Alternator, needs rebuilt: $20
FD Alternator, puts out solid 14 volts: $60
The FD alt I bought used on ebay and only used for 5000 miles before upgrading to a Taurus E-fan & Alt. Works like new, just not enough juice to feed the very thirsty taurus fan. No pulley on it b/c I needed to keep the RB dual sheave one for the Taurus alt. Will sell with the S4 alt for $70
N326 ECU: $25
N326 Airflow meter: $30
S4 rear counterweight, a bit rusty: $30
S4 fuel pump hangar: $25
S4 fuel pump (2), not sure if they work: $20 each (might be good for a twin pump setup)
S4 GXL Struts/springs, sagging a bit but functional and the AAS system works: $50
S4 Automatic Transmission, torque converter, driveshaft and crossmember, pulled out at 96k in perfect running shape. Bellhousing was removed to do a compression test on my 20B, but will be included: $75
S4 stock clutch, worn out disc but good pressure plate: $30
S4 turbo in good useable shape, very little shaft play: $55
S4 turbo is in good overall shape with no side to side shaft play, roughly 1mm front to back play and spins easily. Wastegate is unmodded.
Flat bar style adapter brackets for AT to MT conversion, made for s4 but will work on s5 too: $10
The AT to MT adapter brackets are made out of 1 1/4" wide by 1/4" thick flat iron and were only used for 6 months. Still in excellent shape with no visible evidence of distortion.
Also have a clutch fan in decent working shape. Shroud was cut front-to-back to remove, but could easily be glued. $make offer
S4 MT driveshaft with busted front u-joint: $make offer
S4 GXL sawblade wheels with tires. all hold air fine, 3 have good tread, one needs replaced: $75
I'll also consider trades for the following parts:
s4/s5 N/A aftermarket flywheel
polyurethane engine/transmission mounts
urethane suspension bushings
3 good TII injectors, preferably S5 ones for my 20b secondary rail
anything else, just ask
PM me/reply to thread if interested
thanks,
Travis
Last edited by Akagis_White_Comet; 04-27-2010 at 12:05 AM. Reason: added more parts and info
Akagis_White_Comet is offline   Reply With Quote
