| FujiRacing LLC ROTARY ENGINE SPECIALIST - At FujiRacing we are commited to giving you the best quality product and service with the lowest prices. We work with some of fastest professional tuners and racers in the world. We are in the business to simply make your car go faster and handle better. www.fuji-racing.com 352-217-5554 |
Rep Power: 21 ![]() |
Can you backfire out of the itbs?
been doing some tuning and we seem to be getting a loud noise under WOT at higher rpms. Not sure if its the exhaust blowing through something or if the engine is back firing through the ITBs. Trying to determine the possibility of that.
Rep Power: 17 ![]() |
Never experienced that at WOT.
Jimmy FujiRacing www.fuji-racing.com 2010 13B Rotary Miata Semi-PP 2009 REDLINE TIME ATTACK Modified Class Winner Nashville & Englishtown NJ.(Miata Piston Motor n/a) 2008 REDLINE TIME ATTACK Overall Winner VIR Street Class (Miata Piston Motor n/a) 1990 FC3S Street Car |
You would have to have your trailing spark really -really- advanced, I would think. So advanced that the trailing was firing about 90 degrees BTDC or such.
Easy check, disconnect the trailing spark and run it and see what happens. I don't think it's possible to have the leading plug open to the intake valve, so without trailing, it should be impossible. |
