Old 01-09-2010, 09:17 PM   #1
Rotarytech7
460Hp FullStreetport N/A
Rotarytech7's Avatar
Rotarytech7 is on a distinguished road
Arrow miss firing
My Fc started to miss fire today...and it shuts off if I don't give it gas...wat could that be?
[[Anti-Piston]] ;P
Rotarytech7 is offline   Reply With Quote
Old 01-10-2010, 01:31 AM   #2
Engine is dead and needs to be rebuilt and / or replaced.
Old 01-10-2010, 01:37 AM   #3
lol, grumpy today, aren't we?
Old 01-11-2010, 08:01 PM   #4
He did say what it COULD it be, right?
Did I say something wrong?
Are you saying a hurt motor could not exhibit those symptoms?
Old 01-10-2010, 12:20 PM   #5
Typical Ted response.
Do a compression test and get back to us.
Old 01-10-2010, 08:47 PM   #6
Rotarytech7
Ok today I turned it on and it started to let out white smoke...which means to much oil is getting in right?
[[Anti-Piston]] ;P
Old 01-10-2010, 09:40 PM   #7
White smoke is generally coolant burning.
Old 01-11-2010, 03:47 AM   #8
Rotary#10
Rotorhead
Rotary#10's Avatar
does the exhaust smell kinda sweet? if it does your burning coolant.
Currently running:
90 N/A GTUs..
Running project car
89 N/A GTUs in Black #2
10/6/18
Old 01-11-2010, 11:10 AM   #9
Rotarytech7
ok if its coolant or water wat does that mean? do i have to rebuild?
[[Anti-Piston]] ;P
Old 01-11-2010, 11:16 AM   #10
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
Seriously though how much "white" smoke and for how long after start up, it is cold outside right now, think about how you can see your breath outside, the condensation that builds up from the temp difference in the exhaust will "burn off" almost like the vapor when you boil water. . Have you tried replacing the fuel filter? And check to see if your pump is on the fritz, my car would run one day, not the next, run great the next, then like crap the next. Replaced pump and all my problems went away.
Old 01-12-2010, 05:22 PM   #11
Rotarytech7
No u know ur actually right lol I do have to rebuild...one of the rear rotor seals is bad :/ but guys thanks for the support and for trying to help me figure this out...I will be getting back to u if I have any questions on the rebuild
[[Anti-Piston]] ;P
