Old 10-25-2009, 02:36 PM   #1
REVIT93RX7
REVIT
REVIT93RX7 is on a distinguished road
Pictures of horn location
I'm trying to install my horns but cannot remember where they are mounted. I know they are mounted behind the front bumper cover but which holes to use?. Does anyone have a picture of the location?
Thanks
REVIT93RX7 is offline   Reply With Quote
Old 10-25-2009, 05:58 PM   #2
BigIslandSevens
BigIslandSevens's Avatar
Are you running a stock front bumper with the reinforcement? I believe that it is the holes on the outer most section of the front cross support bar. The ones outside of the ground strap connections.
Here is a shot of mine. The passenger side is in the correct spot I think,..I run a GTC front bumper so i have moved things around alot cleaning up the bay area
Old 10-26-2009, 07:18 AM   #3
REVIT93RX7
REVIT
Horn Location
Thanks for the response. I do have the stock bumper cover.
Old 11-04-2009, 03:54 PM   #4
Mr. Seven
The Professional
Mr. Seven is on a distinguished road
hahaha...not to thread jack but anyone know where the airbag sensors are? thanks...
Mr. Seven is offline   Reply With Quote
Old 11-04-2009, 04:06 PM   #5
BigIslandSevens
There is one that is located on the hood latch itself. It feeds along the cluster of wires back to the ABS unit area. The LFT and RGT side sensors I believe mount next to the oil coolers on the frame rail. I will double check on my car. That is where the FSM is pointing me though.
After looking at mine they are in fact mounted near the oil coolers. They mount on the inner support above the oil coolers. I snap a pic tommmorow if you need one.
Dave
Old 11-09-2009, 12:53 PM   #6
REVIT93RX7
REVIT
Airbag sensors
Yeah the front ones are mounted next to the oil coolers. The hood latch and there also is one under the dashboard in the center of the car up against the firewall.
Old 11-10-2009, 04:09 PM   #7
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
sorry pics are small but take a look this might help
http://s426.photobucket.com/albums/p...103082103a.jpg
scroll through these and will give u general idea where they go
http://muibubbles.blogspot.com/2008/...mentation.html
Bubble Tech
www.BubbleTech.us
muibubbles is offline   Reply With Quote
Old 11-12-2009, 07:21 AM   #8
REVIT93RX7
REVIT
Horn
hey thanks for the reply. The pictures helped alot.
Old 11-13-2009, 01:31 PM   #9
muibubbles
Bubble Tech
muibubbles's Avatar
np, i learned things tend to be a lot easier with pics! im a visual learner so i try and take a lot of pics!
Bubble Tech
www.BubbleTech.us
Old 11-20-2009, 01:28 AM   #10
Gomez
2001 RX-7 RZ
Gomez's Avatar
Gomez is on a distinguished road
Change them and put RX-8 horns on it.
Your FD will love you for it.
They are MUCH better.
Gomez is offline   Reply With Quote
Old 11-20-2009, 09:40 AM   #11
REVIT93RX7
REVIT
Horns
Where did you get the RX8 horns. They do look cool. Is the sound any different?
Old 12-27-2009, 05:03 AM   #12
Gomez
2001 RX-7 RZ
Gomez's Avatar
I bought them new from the dealer.
They sound much better than the poxy originals.....and have a good quality baaaarp sound.
Find an RX-8 and try them out.
Old 01-03-2010, 12:24 PM   #13
REVIT93RX7
REVIT
Horns
Thanks
