Old 06-16-2009, 12:22 AM   #1
jkstill
jkstill is on a distinguished road
FD and RX-8 Diffs interchangeable?
There's a thread at the other forum discussing interchangeability of RX-8 and FD differential parts.
http://www.rx7club.com/showthread.php?t=797818
It is known that the 4.44 ring and pinion gears from an RX-8 manual diff will bolt up into a FD diff.
That seems a nice compromise compared to the 4.77 gears that many autoxers use. While I autox my car, I also do track days, so the 4.44 would get me out of the corners faster in 2nd gear at autox speeds, but still be tall enough for track use.
So, I bought a low mileage 2005 RX-8 Manual diff with the 4.44 gear set.
The question that remains unanswered is this: Does an RX-8 diff bolt right up to an FD? There are indications in the other thread that this might be true, but no solid answers yet.
If so, that would sure simplify getting the 4.44 gears in my FD.
Anyone here know?
I was going to look on the rx8club.com forum as well, but it is currently down.
jkstill is offline   Reply With Quote
Old 07-15-2009, 05:47 PM   #2
afgmoto1978
afgmoto1978's Avatar
I too would like to know this.
Old 07-15-2009, 06:26 PM   #3
prrex4ever
prrex4ever's Avatar
I also wonder if they are any stronger.
Old 07-16-2009, 01:34 PM   #4
jkstill
This thread indicates that 4.77 gears from a Kia Sportage can be put in an FD diff - for < $300.
http://www.hacstl.com/forums/showpos...81&postcount=9
Apparently this is fairly well known in the S2000 Community.
Old 07-16-2009, 02:47 PM   #5
afgmoto1978
I forsee having two diffs, one with a 4.44 and another with a 4.77 depending on the track and event. Hmm...
Old 07-16-2009, 04:11 PM   #6
Monkman33
Still Building my FD
I am definitely going to get a 4.44.... but that 4.77 is very tempting for autocross...
Does anyone make a taller 5th gear? Then I could run the 4.77's and still be able to hit the freeway every now and then.
Old 07-17-2009, 02:34 PM   #7
afgmoto1978
Well had an close look at the RX-8 Diff and it won't work with FD powerplant frame or diff mount. Bummer.
Old 07-18-2009, 11:12 AM   #8
jkstill
From what I have read I think the internals may be interchangeable.
I had the entire RX-8 Diff - it was pretty obvious that the complete thing would not be a bolt in. That would have been sweet.
Whenever I get around to the swap, I will find out if the diff assembly is interchangeable.
Old 07-17-2009, 04:41 PM   #9
Rotary Inspired
Rotary Inspired is on a distinguished road
I have read you have to remove the gears and put them in the FD Diff. Hope this helps.
If you wanna become ASE certified buy the RX7.
Rotary Inspired is offline   Reply With Quote
Old 07-18-2009, 09:20 AM   #10
sk8world
600rwhp club member.
sk8world is on a distinguished road
better be just the gears. I just bought a 4.44 ring and pinion to go in for drag racing.
6.? @ 11? drag pass
http://www.youtube.com/watch?v=9wfxT2RMr7c
sk8world is offline   Reply With Quote
Old 07-20-2009, 08:18 AM   #11
SPICcnmFD
SPICcnmFD's Avatar
That would be really nice if they are. I've been wanting a diff. set but IMO 4.3 isn't worth the money and 4.77 is just to much. I've always wanted something close to 4.5.
1993 Rx-7 SM2 #11
At the local AutoX:
http://www.youtube.com/watch?v=9VOSQkkSLQs
Speed for Sale shootout 2007:
http://www.youtube.com/watch?v=JiqlyAkGmpg
A few laps at Barbers:
http://www.youtube.com/watch?v=6_h5q...x=0&playnext=1
Old 07-31-2009, 01:39 PM   #12
Monkman33
So the 4.44:1 isn't close enough to 4.5:1 for you?
Old 07-31-2009, 07:03 PM   #13
SPICcnmFD
SPICcnmFD's Avatar
Yes it is that's why it would be nice if it's interchangable.
1993 Rx-7 SM2 #11
At the local AutoX:
Old 08-04-2009, 11:22 PM   #14
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
Only the RX8 ring and pinion can be used as a replacement in an RX7 diff, you can not use the RX8 differential case or differential.
Hope this helps,
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
