Old 03-08-2009, 11:40 AM   #1
silverfd3s
silverfd3s's Avatar
silverfd3s is on a distinguished road
need injector resistor help.
i just installed the kg fuel rail and injectors.850/1600cc.they come with 4 inline resistors for the injectors.where do i tap them in at? what color? any help or diagram would be great.thanks,jay
silverfd3s is offline   Reply With Quote
Old 03-08-2009, 01:03 PM   #2
BSC Motorsports
BSC Motorsports's Avatar
BSC Motorsports is on a distinguished road
Safest bet is to tap them into the harness down by the ecu so they're not exposed to vibration and heat. They go on the ground for the inj. All you need is the ecu pinout. Do a search for the fsm.
Brent
www.bscmotorsports.ca
BSC Motorsports is offline   Reply With Quote
Old 03-09-2009, 12:22 AM   #3
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
A better option would be to get an FJO injector driver. It will convert the saturated pulse to a peak/hold and will work with low or high impedance injectors. You can get a Denso to Bosch conversion harness at one of the E-85 conversion stores and not even have to cut your stock engine harness.
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
Old 05-15-2009, 11:32 PM   #4
Caim
Caim's Avatar
Caim is on a distinguished road
Dan
This is def true... this is on my near future shopping list.
Caim is offline   Reply With Quote
Old 03-09-2009, 07:34 AM   #5
BSC Motorsports
Never used the adaptor harnesses, I'll have to check that out. That would be nice rather than cutting the harness. How much are they?
Brent
Old 03-09-2009, 02:21 PM   #6
Chadwick
Chadwick's Avatar
Brent
RC engineering sells them for $18, but I found them cheaper last time I did a search. Here is a link to RC http://www.rceng.com/Denso-Clip-Connector-P48C9.aspx
Dan
05 Silverado Z71
08 Mini Cooper
Old 03-09-2009, 05:34 PM   #7
BSC Motorsports
I misunderstood, I thought you meant something different.
Brent
Old 03-10-2009, 04:48 PM   #8
Chadwick
Chadwick's Avatar
Here is a link to the FJO injector driver http://www.alamomotorsports.com/fjo/injdrvr.htm
Dan
05 Silverado Z71
08 Mini Cooper
Old 03-15-2009, 11:28 AM   #9
silverfd3s
silverfd3s's Avatar
well my harness was already cut.and i didnt know if anyone has done this before.and just needed some help.if you have and have any pics please let me know.thanks,jay
Old 05-13-2009, 04:45 PM   #10
Kim
OBEY YOUR MAZDA
Kim's Avatar
Kim is on a distinguished road
Im in the middle of installing the KGParts fuel system too.
I'm no ecu pro and the kit did not come with instructions.
Does this seem right?
My MS-Paint skills though, are badass
Kim is offline   Reply With Quote
Old 05-14-2009, 06:18 PM   #11
Kim
OBEY YOUR MAZDA
Kim's Avatar
Just checked with the RX7club - i'm correct as usual
