Old 10-12-2008, 01:33 AM   #1
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Side-exit exhaust
My turbo project has been delayed until next year, unfortunately, but in the mean time my exhaust system was needed for another car, so Jeff20B welded me up a new one. We decided to have it exit out the side so as to avoid having to go up and over the axle (we were lazy and short on pipe ). We used two old Rotary Engineering glasspacks after the stock manifold, with some Monza/Ansa/Pacesetter tips. Turned out pretty well.
Old 10-22-2008, 04:34 PM   #2
pinoyremix
pinoyremix is on a distinguished road
i must say...what you did with the exhaust is interesting...
pinoyremix is offline   Reply With Quote
Old 10-23-2008, 02:48 PM   #3
ratboy
ratboy's Avatar
ratboy is on a distinguished road
looks and sounds pretty good, but Im gonna laugh when you set your tire on fire!
ratboy is offline   Reply With Quote
Old 10-23-2008, 02:57 PM   #4
I was thinking the same about the tires. I haven't heard it though...maybe later.
Old 10-23-2008, 04:51 PM   #5
PercentSevenC
Custom User Title
To tell the truth, I was concerned about having the exhaust that close to the tire, but it doesn't seem to be a problem. Eh, it's temporary, might as well try something different.
Old 11-20-2008, 05:10 PM   #6
BigTeddy
BigTeddy is on a distinguished road
you don't have to go up and over the rear axle...you can go under the rear end with no problem...I have done many exhaust systems this way with no problems all the way up to 4inch's
But your set up Sounds pretty sick and looks cute too...
One Turbo At A Time
BigTeddy is offline   Reply With Quote
Old 11-20-2008, 10:19 PM   #7
Fidelity101
Reliable Source
Fidelity101's Avatar
90 degree bends are bad for airflow.
My Rx-7 Vids
Old 11-20-2008, 10:22 PM   #8
jtbshaw
ORD - Old Rotary Dude
jtbshaw's Avatar
That's awesome! I will be doing this on a bud's car tomorrow. I'm helping him install a bridge-port in his GSL-SE that he rally-x's. I had planned to to run twin resonators out with twin tips....full 2" x .120" wall tubing....all rotary draw bent to shape.
Old 11-20-2008, 11:13 PM   #9
BigTeddy
its only one so the air flow is not restricted that bad if at all...Now if he would have thrown left and right 90's and up and downs and loop d loops then yeah the exhaust would have been garbage...
But the setup he has is just fine
One Turbo At A Time
Old 11-21-2008, 12:43 AM   #10
PercentSevenC
Custom User Title
If we'd gone over the axle it would have used up a full u-bend.
I won't likely do it this way again, but it is kinda cool. I'm just surprised how tolerably quiet it ended up being. It does drone a little bit at certain RPMs, but not in the freeway cruising range, thankfully. Not bad for a pair of old glasspacks.
BigTeddy: We probably could have done that, but again, it would have taken more pipe. Question, though: is it okay to do that at stock ride height with stock soft springs? If it makes more sense, I could do my 3" turbo exhaust system under the axle.
Old 11-21-2008, 02:26 AM   #11
BigTeddy
Originally Posted by Jeff20B View Post
What you save in less bends, you loose in other ways. Especially with 3". Scrapy isn't just a disease. Steve went up over his rearend and makes 300 HP even with an RB muffler.
Hey, I want your exhaust when I drop the experimental engine into my car.
jeff your following me
One Turbo At A Time
Old 11-21-2008, 02:24 AM   #12
Jeff20B
Jeff20B's Avatar
Old 11-21-2008, 02:25 AM   #13
BigTeddy
Player im telling you...I did the setup and im getting ready to do the setup again for my all motor setup with a 3inch exhaust from front to back and under the axle with...My car is track setup and lowered but i have never ran into a problem...
When i used to run my car on the street it never scraped or hit anything...I will post pics here soon so you could see
One Turbo At A Time
Old 12-21-2008, 09:16 PM   #14
whitey85mtu
whitey85mtu is on a distinguished road
sounds nice, how did you get such response from your engine? i'm assuming you have a lightweight flywheel, is that is?
whitey85mtu is offline   Reply With Quote
Old 12-22-2008, 01:34 AM   #15
PercentSevenC
Custom User Title
Combination of large ports, a decent-flowing carb with no emissions junk, a healthy (though still stock) ignition system, and, naturally, a lightweight flywheel (it only weighs 8 lbs. ). The response isn't quite as sharp now with the extra rotating mass of the supercharger, but it's still pretty good for a streetport.
