| DGRR Archive Threads from Previous Deals Gap Rotary Rally Events. |
Home-brew Rotary
To-Do List DGRR 2015
No to-do thread yet?
Anyway for me, I have to fix an exhaust leak on my FC which Ive decided to resurface all the flanges, fix a broken stud, and replace gaskets.
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. |
#2 | |
I have to do nothing because I am not going..
Rep Power: 22 ![]() |
Clean fuel tank, a few minor things, break in new motor.
No pressure.
I SEE DEAD PEOPLE
New tires on the truck-done
Oil change on the truck-done Completely new brakes on the truck-done Load up tools and junk in the trailer-done Gotta gas up the car and go through her tomorrow. Putting more money in the tow vehicle than car SMH.
VIN-AUTO Rotary list of Fails below: 86 mazda rx7 csp 61 N/A= because RACECAR 87 mazda rx7 t2 with 13b-re cosmo GT42= FKN RUNS!!! 03 Dodge Viper SRT-10 Vert 06 dodge ram 2500 Megacab turbo Cummins=puller 16 MB ML350 Last edited by rx7 vinnie; 04-02-2015 at 03:54 PM. |
Mount new Bridgestone RE760 tires and probably new Hawk HPS pads and rotors on the rear. I would like to do new struts, but probably won't before the event. The O.E. ones are starting to show their age, but aren't leaking yet. I have to take the converter back off too, because we just ran through emissions.
Waffles - hmmm good
1. coolant leak on intake
2. oil leak on oil pedestal 3. replace hawk brake pads cause they squeal so bad I can't stand it 4. change oil and coolant while I'm at it 5. check exhaust hangars all around 6. Clean some waffle wheels up 7. maybe do something with the air cleaner for the nikki.
Rep Power: 10 ![]() |
![]() ![]() ![]() ![]() ![]() :smi lielol5:![]() ![]() I think that about sums it up this year
Gold Wheels FTW
Put gas in the MR2...
Cause I have no time for the 8 this year.
My Cars: 1974 RX4 Coupe 1991 FC3S RX7 - Sold 2003 ZZW30 MR2 (Rotary swap after RX8) 2004 SE3P RX8 (20B Swap in the works) |
#9 |
Epic fail for trying to clean out the tank the 'easy way'.
On to Plan B: see if the tank in the white car is clean (since it was on the road in the last 2 years), if so it will be swapped. Otherwise, Plan C: I have ordered a POR 15 Fuel Tank kit. That'll work, but it time intensive. Last ditch, Plan D: drive Deathtrap.
#10 | |
Plan C is a go, but it hasn't arrived yet! Dammit Amazon!
#11 |
Buy beer, pack, put gas in someone else's car
-75 RE_W_PU - -76 Hercules W2000 - DGRR 2012 3rd place Old School -75 Hercules W2000 MSO - DGRR 2011 Peoples Choice - April 2011 Rotary of the Month ![]() -Rotary snowmobile powered go kart - DGRR 2012 Peoples Choice - RIP |
#12 |
Rep Power: 20 ![]() |
Ha Ha, that's essentially my plan if the 7 isn't ready minus the gas part since I'll just simply drive the daily worse case scenario.
The 7 To-Do list: -Install wire harness I haven't received yet (hopefully soon) -Install coil mount I haven't received yet (hopefully soon) -Assuming there's no issues with parts mentioned above then. . With help, get car tuned and running efficiently. . After those it'll be all the standard things like tire pressure, fluids, and wash
1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4 |
#13 |
Dj that's everyones plan D
#14 |
counting down till DGRR
Get Tires, install new brakes, gas up & drive.
-74 RX-4 -84 REW GSL-SE Past rides -05 REW Swapped RX-8 -93 FD base |
#15 |
Rotary Non-conformist
Some more boost tunning on the AVCR boost controler
![]() A few small things on the custon FMIC setup clean gas and go
