Old 08-25-2011, 06:54 AM   #1
fc nut
member
fc nut is on a distinguished road
new old car
this saterday i'll be picking up an fb that i've been waiting patiently for 2yrs. the owner finally desided to sell. it's been setting for 7yrs waiting for someone to get it back on the road.it's an 84 gsl se,permison red with brown interior. i'll post pics when i get it home.
leaving my carbon footprint....one start up at a time
fc nut is offline   Reply With Quote
Old 08-25-2011, 07:25 AM   #2
Kentetsu
Kentetsu's Avatar
Very nice. Get her running and then bring her up sometime.
Old 08-25-2011, 09:45 AM   #3
Gregory Casimir
nice would like to see the pics of it.
Gregory Casimir is offline   Reply With Quote
Old 09-01-2011, 06:42 PM   #4
fc nut
member
here are some pics of us pulling it away from the brush.
here's one of the critters that came with the car
i took it to a car wash before i got home and sprayed what i could off.
i removed most of the interior to clean it.all the padding under the carpet needs replaced,a dog pissed in it after it chewed on the pass seat. it's no problem though.
i found a small amount of rust.
so there she is. the wife is mad that i bought another car, but she knows it's the one i've been waiting patiently for almost 3yrs.
Old 09-04-2011, 02:21 PM   #5
Nutsid
Temporarily insane.
Nutsid's Avatar
It looks like you'll have a lot of work ahead of you. Good luck with it all. I miss my FBs.
Kindle
Nook
Old 09-06-2011, 04:00 AM   #6
goose
goose is on a distinguished road
Good luck with it... I love FB's!!!
goose is offline   Reply With Quote
Old 09-07-2011, 04:53 AM   #7
fc nut
member
it's gonna take a little bit of time to get her back on the road,but it'll be worth it to save another 7 from the crusher. that's where it was headed if i didn't buy it. she should be running and driving by next year. right now,i've got most of the interior out so i can start cleaning it up.
Old 09-27-2011, 09:46 AM   #8
fc nut
member
Exclamation
this past weekend,i put atf in it and the engine turns with a ratchet. as i was rotating the engine by hand it felt like it was catching on something and then i heard a "pink!". when i rotate it now,it doesn't make a noise,but it does feel like it's catching on something. could it be a broken apex seal?
Old 09-27-2011, 10:02 AM   #9
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Originally Posted by fc nut View Post
... i heard a "pink!", ...
Can't be good. I would break it open and see what the damage is before trying to start it. Might save you some parts on the rebuild.
Old 09-27-2011, 11:55 AM   #10
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
Here is 2 new housings for a good price (not mine, I just ran across them looking on CL).
http://orlando.craigslist.org/pts/2615244870.html
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 09-27-2011, 03:27 PM   #11
fc nut
member
i have a strong running s4 n/a engine in my fc that i'm considering swapping in.
Old 09-28-2011, 04:55 AM   #12
fc nut
member
i pulled off the exhaust manifold last night and turned the engine. i put my finger in to feel if something was loose inside there and it felt like all the seals were still in the rotors. the engine is still in the car,so i couldn't see in the ports very good.i'm baffled. i'll probably pull it out and tear it down to see whats up with it.
Old 10-09-2011, 06:56 PM   #13
fc nut
member
there was nothing loose in the engine. i tried to start it today and it wasn't getting to the plugs. it's getting fuel,the coils are making spark. i checked the cap and rotor and there was some corrosion on the terminals. i'm gonna change them out and try again. it wanted to start as bad as i wanted it to.
Old 09-27-2011, 01:06 PM   #14
Kentetsu
Kentetsu's Avatar
Pull off the exhaust manifold, then you can look inside the engine while you rotate it. You never know, it might just spit up an apex seal.
Old 11-24-2011, 11:38 PM   #15
dabranco
dabranco is on a distinguished road
You get her running yet? Looks good man.
dabranco is offline   Reply With Quote
