Old 03-01-2016, 02:52 AM   #1
Bushing sleeve rusted to bolt
About a month ago as I was removing my passenger rear upper control arm, I discovered the bolt was rusted into the metal sleeve and I was not able to remove the arm. I installed these SuperPro bushings probably about 8-10 years ago, and they've been doing great other than one little squeak, which I discovered to be this bushing because the sleeve would rotate within the bushing as I was trying to remove the bolt and it would squeak.
I bought replacement arms and all new bushings and I'd like to avoid this problem in the future. I was thinking of lubing up the bolt shank either with the same lube used on the bushings or maybe using anti-seize. What do you guys think would be better, or do you believe one or both would cause a problem? I got a replacement subframe as well so I could get this car back on the road sooner. I don't want to have to go through this again.
Old 03-01-2016, 07:53 AM   #2
C. Ludwig
Rotary Masochist
Anti-sieze.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 03-01-2016, 09:14 AM   #3
Definitely anti-seize
Old 03-01-2016, 09:23 AM   #4
Astro-glide
Old 03-01-2016, 09:41 AM   #5
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Astro-glide
Difference between peanut butter and jam???
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-01-2016, 12:14 PM   #6
I'd recommend silicone paste.
3M makes a very good one!
You can use this stuff on rubber, polyurethane, metal-to-metal, etc.
Perfect for bushing installs...
Old 03-01-2016, 02:44 PM   #7
C. Ludwig
Rotary Masochist
Astro-glide
This. /thread
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 03-01-2016, 03:35 PM   #8
chibikougan
chibikougan's Avatar
Agreed I would use a Copper, Silver, and or Moly fortified anti seize.
Check out Loctite they have a lot of new product too.
Old 03-01-2016, 03:30 PM   #9
Have actually used Kentucky Jelly for assemble of things
Old 03-02-2016, 02:29 AM   #10
Thanks for the input guys! I have two bottles of anti-seize (because I lost the first bottle and bought another before finding the first one lol), but it's Permatex. I'll have to see what's in it. I'm also planning on liberally coating the spindles when I reassemble the rear hubs since my original pieces are rusted together there too. I'm just using it on all the things at this point.
Astro-glide is a close second though.
