Air Pump removal, Something you need to know.
The first thing most people do when upgrading their car is to remove the Air Pump and throw on some under drive pulleys. The problem with this is now the contact patch on the water pump pulley is greatly reduced and most find that they can turn it with their fingers even with the belt tightened above stock tension. What most people then do is over tighten the belt to stop the slipping.
The rotary engine uses hydrodynamic journal bearings to support the eccentric shaft. The way it works is by flowing oil under pressure between the bearing surface and the shaft and basically “floating” the shaft through the fluid dynamic effect. Increasing the lateral load to one side on the shaft reduces how well the journal bearing can do its job of “floating” the shaft and results is metal on metal contact and accelerated wear. Over tightening the belt creates just this type of lateral load. Pictured below is just one example of excessive bearing wear caused by running under drive pulleys without the air pump and over tightening the belt to compensate. The first picture is of the front bearing on two motors with a similar history. Both ran Mobil 1 10w30 most of their life and were autocrossed. The 99,800 mile motor stayed in stock form until it met its end due to a water jacket o-ring failure. The 66,000 mile motor had the air pump removed and under drive pulleys install around 53,000 miles. It also met its end to a water jacket o-ring failure. The front stationary gears are in their correct orientation so what you are looking at is the top of the bearing as it sits in the motor. The copper color area is the wear. ![]() ![]() The next image is of the rear stationary gear bearing. The picture is upside down to the way it installs in the motor so you are looking at the bottom of the bearing surface. ![]() Close up of rear bearing wear: ![]() As you can see the bearing wear is exceptionally worse on the 66,000 mile motor and the wear pattern on the bearing clearly shows the extra load applied by the lack of an air pump or idler in its place is the cause. The only solution is to keep the air pump or replace it with an idler pulley. Currently there are three companies that have a solution available now or in the near future. They are: Pineapple Racing: $179.00 + shipping Requires removing two bolts out of the water pump housing to install. Tweakit Racing: $142.00 shipped Bolts to Air Pump stock mounting points ![]() Garfinkle Motor Works: Will be released soon. Price to be determined, but estimated below $200 Bolts to Air Pump stock mounting points
![]() 93 RX7 BB (Race Car) 93 RX7 SSM (Soon to be IBM and a daily driver) 05 Silverado Z71 08 Mini Cooper 80 LS RX7 (for sale) Last edited by Chadwick; 01-29-2009 at 11:04 PM. |
A worthy mod for those without the air pump.
FYI a local tuner (Portland OR) actually cracked the E-shaft by using too much belt pressure in his personal 600+ HP car. He probably added the pulley following that. I would be in on the group buy, but already have Pineapple's kit. |
Sua Sponte
*cough* shameless plug *cough*
All kidding aside, this is a great product. I had a chance to check it out at the shop a while back. I will more than likely be getting one of these in the near future. Dan and crew(Brian and Andrew) are very knowledgeable... just about as knowledgeable as they come. Dan is one of the few people that I will let work on my car due to piece of mind that it is going to be done right.
Road Atlanta August 2011 NASA TT 1:33 http://www.youtube.com/watch?v=IFY00PAK_Ps Traqmate's video of my car from the 2011 UTCC at VIR http://www.youtube.com/watch?v=2Zcn6...layer_embedded Video of Yellow LS1 FD at NASA TT at VIR http://www.youtube.com/watch?v=e6k0lJkcwrM |
Member
When my OE motor "met its end due to a water jacket o-ring failure", Dan was top on my list of builders for that reason. I'm going to get one from Tweakit because they're so close, and he can "supervise" my install.
93 VR RX7 09 Mini Cooper 75 Cosworth Vega
Needing a new tow rig.
as far as these go thats all well and good but some of those "idler" pullies may get in the way of peoples single turbo's. so im kinda curious if anyone has a replacment waterpump pulley that has ribs in it to run the belt around it instead of on the back of the belt? wouldnt the ribbing give you the extra "grip" you need to prevent slippage at the correct belt tension?
z ya sorry guys i thought about this one for like ten minutes before still posting it and then did anyway....oops BUT i do have a picture on my home computer that has it run exactly this way so maybe he has a different impeller or is just waiting to blow his motor i wish i could post it here as the rest of the setup is pure track... Last edited by proz07; 12-12-2008 at 05:47 AM. Reason: realization |
#6 | |
David Jerome Broker for Speed For Sale LLC (David@SpeedForSale.com) (Pre-owned RX7/sports car sales & new parts sales/installs/tuning) ![]() PM me about low priced, high quality port work
Put it in her butt
i would love one but it seems that with the GT42 i have little to no options when it comes to this, the only one that i think might fit ix the pineapple one, it seems small but im still not sure it will fit.
GT42, Gotham Racing Monster Port, Zoom-Zoom Rebuilding the GT4202, hopes that all:wallbash: WTB: passenger oil cooler WTT: Carbon Fiber VIS Vader Hood for Carbon Fiber Scoot Hood www.azrotoryrockets.com |
I have a question: Don't most people remove the air pump to make room for piping or a single turbo?
Will Garfinkle's kit allow for this? Thanks for the post this is really good info.
This is going to tear |
#9 | |
. None of them would have worked for his.Dan |
#10 |
Rotary Wannabee
Dean, I think those are actually your 99K bearings in the picture. Your motor was surprisingly nice inside when we disassembled it.
-Brian ![]() '95 Mazda Miata R package '90 Mazda Miata turbo '06 Chevrolet Trailblazer SS '01 BMW 325Ci '91 Honda CRX hf |
#11 | |
Viable Fossil
![]() I still run stock twins, but for me the point of removing the airpump was for (after emissions delete) the room, weight reduction, convenience and looks. It's been said before, but the advantage for an idler pulley is to keep the stock belt in full contact with the waterpump without having to go to an over-sized (under-drive) pulley set. I autoX but don't track. So I don't spend extended periods of time at high RPM and I don't have a need for the under-drive aspect. Same situation for guys that only street their cars. Not to mention the possible issues during periods of heavy electrical loads at idle. Chadwick's post is just more reason why I'd rather spend my money on a good idler pulley than an underdrive set. Although I hadn't considered accelerated bearing wear, I have personally seen a guy way over-tighten the belt on his under-drive pulley set because it kept squalling at cold start-up. You could have played a tune on the belt, but hey...they were much prettier than mine.
Jim VR R1 FD Last edited by Signal 2; 12-11-2008 at 11:23 AM. |
#12 | |
Member
redline, here I come
#13 |
lol!
#14 |
I just put my name on the GB for your idler pulley. Can't wait for this to go through!
'93 RX-7 VR Touring (Weekend Rocket) '06 3 (Daily Driver) '04 6 (Wife's) '06 Yamaha FZ6 (Gas Saver) |
#15 |
hey they look like it could fit with a single on the tweak it set...
