Old 04-25-2008, 02:42 PM   #1
MidnightOwl
BAND. You got talent.
MidnightOwl's Avatar
MidnightOwl is on a distinguished road
o2 Sensor
My o2 sensor has some frayed wire action at the sensor itself, so I went to get a replacement from Pep Boys. I need to know if it's gonna be the right part, it's part # 11027 and it's a universal o2 sensor that their computer called for. Just double checking to see if this is going to work for me. I went ahead and got it since it was only $20, so if it's wrong, return mania.
I've have an 87 turbo engine, if you were wondering.
88 Turbo Vert - mostly stock, S5 turbo, full exhaust, Greddy Profec B Spec II, full emissions removal
90 240sux - daily driver of DOOM.
www.daviddrinkard.com
MidnightOwl is offline   Reply With Quote
Old 04-25-2008, 03:28 PM   #2
Apac tii
Apac tii's Avatar
Apac tii is on a distinguished road
I don't see why it wouldn't work, but I am not completely sure. Just try it out it can't really hurt anything.
1988 Mazda RX-7 T2(list of mods here)
http://designengineeringworks.com/project_cars.php
2004 Saturn Ion Redline(dd)
1999 Mitsubishi Galant V6(the backup beater)
Apac tii is offline   Reply With Quote
Old 04-25-2008, 03:44 PM   #3
Boostmaniac
Verified, I use the same one.
88 Turbo. It is a bitch to get to it though, you might want to remove your precat/downpipe to make it easier to get in. Should have a slightly longer wire also that makes it very easy to wire up.
Rock it son.
***edit*** mine was hard because I have full emissions and an ABS pump in my way.
Old 04-25-2008, 05:09 PM   #4
MidnightOwl
The downpipe is off of the car, and I have a lift, so it's not a problem at all.
Old 04-25-2008, 05:30 PM   #5
Boostmaniac
I hate you so very very much.
Old 04-25-2008, 05:59 PM   #6
MidnightOwl
Already finished up the job, haha.
Old 04-25-2008, 06:09 PM   #7
Apac tii
Apac tii's Avatar
Yeah a lift makes things easier i'm glad I have one of those to use too, sorry to all you guys that get to know the concrete so well.
Old 04-25-2008, 06:44 PM   #8
MidnightOwl
I did 99% of my swap without a lift, and it SUCKED. We got the lift about three months ago, and it makes stuff a whole heck of a lot easier.
Old 05-01-2008, 11:18 PM   #9
Jackstands and a Euro-spec inspection pit FTW!
Old 04-25-2008, 07:53 PM   #10
Nismo
400WHP or bust
Nismo's Avatar
I have used a O2 sensor for a 3.1L '93 Pontiac Sunbird because it was 30 bucks, and instock compared to the "RX-7 specific" one. Worked fine.
Old 05-01-2008, 11:20 PM   #11
dp
