Old 07-20-2010, 07:35 PM   #1
Rotary91
Rotary91's Avatar
Rotary91 is on a distinguished road
This has been asked, I have read about it but would like to make sure.
Will an s4 OMP work fine with an s5 FC?
'91 FC3s
Rotary91 is offline   Reply With Quote
Old 07-20-2010, 08:00 PM   #2
NO.
Old 07-20-2010, 10:04 PM   #3
Rotary91
Rotary91's Avatar
thank you
'91 FC3s
Old 07-20-2010, 11:35 PM   #4
Nismo
400WHP or bust
Nismo's Avatar
NO.
To build on this; so you might gain a little more knowledge, the S4 is mechanically operated with a shaft from the Throttle Body to the OMP, the S5 is electrically controlled by the ECU.
Originally Posted by Rotary91 View Post
thank you
You are welcome.
Old 07-21-2010, 12:56 AM   #5
FC Zach
FC Zach's Avatar
And to further complicate things, , , You could, but you would have to use an earlier OMP with the appropriate front cover and a re-chipped S5 ECU (to avoid limp-mode).
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 07-21-2010, 09:15 AM   #6
Rotary91
Rotary91's Avatar
Thank you Nismo and I don't think I want to modify this engine just for an OMP, it has 231K miles and is about to die.
'91 FC3s
