Old 04-21-2010, 06:14 PM   #1
rotaryguy481
rotaryguy481 is on a distinguished road
1988 t2 acts like its just flooding -
Aight guys it ran for about a day and quit again I have a 88 t2 no emmisions and it acts like its just flooding I'm getting fire but not sure if my plugs are beyond gone or what I checked the tps the cas and both within rang compression is 115 front and back and it just will not start heavy gas smell really when I do the unflooding prosses don't know what else to do fixing to burn it8????
rotaryguy481 is offline   Reply With Quote
Old 04-21-2010, 06:50 PM   #2
holy crap... not a single period used in that entire sentence with about 15 different ideas.
First things first: Are you having a hot start issue, or is this both a cold and hot start issue?
Second: When was the last time you had your injectors cleaned, and I don't mean you dumped a bottle of alcohol into your gas tank?
Third: What are the conditions of your plugs specifically? Are they old, worn out, wet, etc?
When we know that information we can move on to telling you what's wrong with the car.
Old 04-21-2010, 06:55 PM   #3
ZGN
Administrator
ZGN's Avatar
You should have seen the subject line before I edited it.
Kevin
Old 04-21-2010, 07:12 PM   #4
No I did... But I found humor in turning my head sideways after writing my response and realizing I did that completely by accident (might have to be full screen to get the effect)
Old 04-21-2010, 07:12 PM   #5
rotaryguy481
Fixing to change the plugs and wires, uh the injectors I sent to rc about a month ago. And it does it while cold
Old 04-21-2010, 07:14 PM   #6
Yeah, check the spark. Pull the IGN fuse and have a friend crank the engine, check to make sure you have spark at the spark plugs (IE: pull the plug out and ground it against the block).
Old 04-22-2010, 08:53 AM   #7
rotaryguy481
Got it running the plugs and wires where shot now I got to re stab the cas I stabed it alil advanced
Old 04-22-2010, 10:15 AM   #8
Sounds good... Now we just need to work on your grammar.
/Grammar Nazi
Old 04-22-2010, 11:08 AM   #9
From the other thread...
Are these the original spark plugs you used on break-in?
If so, then a lot of the crap is from the blow-by from the engine breaking in.
I recommend swapping to a new set of plugs after the initial break-in period if the break-in plugs are no good.
duh
Old 04-22-2010, 01:36 PM   #10
rotaryguy481
I'm from Texas there is no grammer here lol. and now how do i get my stock boost gauge to work???
Old 04-22-2010, 01:43 PM   #11
I'm slowly finding out...
As for the boost gauge, check here: Boost Gauge Fix
Old 04-22-2010, 01:48 PM   #12
rotaryguy481
And one more thing sorry guys I really apreciate all yalls help, uh when I get into heavy boost about 4,500 rpms it feels like I'm hitting a rev limitor why could it be should I get a fcd and see if that helps.
