Old 12-15-2009, 04:48 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
S5 n/a engine, S4 n/a trans... which clutch?
I may be coming up on a S5 n/a engine in the future to swap into my S4 n/a. I'd like to use my S4 n/a transmission, but I'm not sure which clutch to use. I've noticed that all the clutch kits I've looked at have different part numbers for S4 and S5. I'm guessing it has to match the transmission, since I can't see how there could be a difference on the flywheel side .
Old 12-15-2009, 05:57 PM   #2
C. Ludwig
Rotary Masochist
You would use the clutch that worked with the flywheel. So you will want an S5 clutch. Still trying to envision the differences. I know the disk itself is the same between the two. The S4/S5 use different bolts for the cover, but I'm pretty sure one will bolt to the other.
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 12-15-2009, 08:52 PM   #3
^^Yep. You go with the flywheel setup on the engine.
