Old 03-03-2008, 06:02 PM   #1
My5ABaby
My5ABaby's Avatar
Vacuum Caps
Has anyone found a good alternative to the crappy vacuum caps from Autozone, NAPA, etc... They always get old and crack on me and start leaking. It's such an annoyance replacing them so often.
Old 03-03-2008, 06:19 PM   #2
I would like some information on this as well. I am tired of replacing all my caps every year. They seem to last until I am on the way home from DGRR, then they fail and begin to leak about 1/2 hour from home.
I am tempted to smooth out and weld them shut.
Old 03-03-2008, 06:29 PM   #3
I have used the silicone caps from the local parts store and they do seem to hold up alot better than the rubber caps.
Old 03-03-2008, 06:37 PM   #4
My5ABaby
My5ABaby's Avatar
Which brand are the silicone ones and where do you get them (NAPA, Autozone, all of the above, etc.)?
Btw... TN representing...
Old 03-04-2008, 11:42 AM   #5
Can't remember the brand, been so long since I had to buy any But I got them at Advanced or O'Reillys.
Old 03-04-2008, 09:53 AM   #6
classicauto
crash auto?fix auto
classicauto's Avatar
Hmm, well its not a "great" or pretty option, but some silicone vac line with a bolt in the end can do the trick. And yeah the silicone (whether in hose or cap form) will last alot longer then rubber.
Old 03-04-2008, 11:32 AM   #7
My5ABaby
My5ABaby's Avatar
I'll probably do that, I don't care how it looks.
Old 03-04-2008, 01:31 PM   #8
My5ABaby
My5ABaby's Avatar
Hmm, all I ever see is the crappy rubber ones. I'll look closer next time.
Old 03-07-2008, 01:11 AM   #9
dregg100
jb weld is your friend!! i have also used that epoxy puddy stuff, it seems to work well too.
'93 SSM Touring-S475...
'87 Tii-LS1/T56
Old 03-07-2008, 09:46 AM   #10
I use those nylon colored caps you can get at the hardware store.
They come in like 3/16", 1/8", 1/4", etc. sizes.
They just look pretty on the engine.
Seriously, I shoot some RTV into the fitting before slipping the cap on.
This is what keeps the fitting from leaking.
The cap is there just to remind me nothing is supposed to go on it.
If I ever want to reuse the fitting again, using a proper sized drill bit will clear out the RTV, and viola...
I don't like the rubber vacuum caps cause they look butt ugly. :P
Old 03-07-2008, 12:45 PM   #11
Thanks Ted. That is what I will do next time the manifolds have to come off.
Old 03-09-2008, 07:01 PM   #12
My5ABaby
My5ABaby's Avatar
I saw some Vinyl caps today at Autozone. Has anyone tried those?
As in, Ace Hardware or something?
And aren't you afraid the RTV will get sucked into the engine or something?
Old 03-10-2008, 11:34 AM   #13
Yeah, figure Ace would have them.
I used to see them regularly at Eagles and Lowes.
I think Home Depot also has them in the miscellaneous fasteners section?
I think they are called "screw covers", or something like that...
They are used to cover the exposed threaded ends of screw when they stick out of things.
Hmmm...I've never had them crack or fail, even with the heat...
In fact, they shrink a little due to the heat for an almost custom fit.
I let the RTV dry overnight before having it handle a running engine, so there's no problem of it getting sucked into the engine.
Most fittings are close to an inch long, so it's going to take more than normal engine vacuum to get dried RTV out of them!
Old 03-10-2008, 12:28 PM   #14
My5ABaby
My5ABaby's Avatar
Like these bad boys?
http://www.pro-dec.com/
Old 03-11-2008, 09:53 PM   #15
Oops, not nylon - sorry, brain barf.
They are *vinyl*.
They come in a ton of sizes, so you just gotta get the right size for a snug fit.
I think the 3/16" ones cover the "small" (3mm?) fittings.
http://www1.mscdirect.com/CGI/NNPDFF...2092&PMCTLG=00
These are used to protect the threads on exposed fasteners.
MSC has them rated to 300F, so they should be able to take the heat.
I also found out that Eagle Hardware & Garden doesn't exist anymore.
Lowe's bought the entire franchise out.
