Old 01-06-2009, 03:02 PM   #1
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
FJO Injector Driver New Version available
Just wanted to pass on that FJO racings second generation injector driver is available. It is about half the size of the first gen controller, easier to install and about $100 cheaper. I found it at Alamo Motorsports for $149.00.
The 3rd gens fuel system uses a high impedance/saturated injector. The common replacement injector for the secondary fuel rail is the Bosch 1680cc which is a low impedance/peak & hold injector (4A/1A). The problem here is two fold, first the PFC injector driver was not designed for the low impedance injector and will burn out in short order and the signal to the injector is not the correct format for what the Peak & Hold injector is designed for.
The common practice is to wire a resister between the Power FC and injector clip to bring the impedance up so you don’t burn out the injector driver but this does nothing to correct the saturated signal being sent to the peak & hold injector. It will operate this way but injector accuracy is greatly reduced. The solution is to use an FJO injector driver. It will convert the saturated signal to the correct 4a/1a signal for the injectors and also is the correct impedance for the ECU.
At $149.00 it is foolish to not use it in place of the hack job resistors.
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
Old 01-06-2009, 04:16 PM   #2
Thanks Dan!
I might have to pick up one of these as I'll be running some 1600s.
Old 01-06-2009, 07:56 PM   #3
afgmoto1978
afgmoto1978's Avatar
I have the older version and does the job very well. Linear injector transition is a huge plus.
Old 01-07-2009, 01:09 AM   #4
Charlie Redden
17+ years...
Charlie Redden's Avatar
Charlie Redden is on a distinguished road
Question Installation
Chadwick,
When you speak of the installation, how easy is it? Electrical work is by far the weakest point in my working on the FD.
FJO's website just states that it installs between the ECU and injectors...
Charlie
Charlie Redden is offline   Reply With Quote
Old 01-07-2009, 02:32 AM   #5
Chadwick
Chadwick's Avatar
Originally Posted by Charlie Redden View Post
Chadwick,
Not that bad, the new one has fewer wires to tap so it is an easier install. Hardest part is getting to the injector wires under the intake. Instructions are pretty easy to follow but they are not rotary specific. I would guess it to be about a 2-3 hour job if you have the right tools and know your way around under the intake manifold.
Dan
05 Silverado Z71
08 Mini Cooper
Old 01-07-2009, 03:01 AM   #6
proz07
Needing a new tow rig.
proz07's Avatar
hasent this been out for awhile now? in anycase i keep reading how it makes tunning transition alot easier and what not. but on 7club they had a discusion about the board that FJO was using would only do the P/H function over 4ms if the injectors being used were not the correct ohms you would fail to reach 4A so it would not drop to the 1A hold until 4ms time had elapsed. basicly running saturated under 4ms on times. not that its a big deal with the benefits it has for other tunning areas and anything above 4ms giving you better fuel economy as well. didnt Howard Colman document a decent milage increase using this?
z
