Old 04-05-2008, 09:41 AM   #1
sprocketford
sprocketford is on a distinguished road
wiring on 1972 RX-2 with 12a
Hello I have a 1972 mazda RX-2 with 12a motor I can't get any spark to make long story short the guy I got from switch some wiring on the wires by the two coils and I am trying fix need some info please?
Thanx Sprocketford
sprocketford is offline   Reply With Quote
Old 12-21-2008, 08:36 PM   #2
capellarx
capellarx is on a distinguished road
try ausrotary
capellarx is offline   Reply With Quote
Old 12-22-2008, 12:59 PM   #3
Atkins Dan
Premium Vendor
Atkins Dan's Avatar
Atkins Dan is on a distinguished road
Is there a way you can post up some photos????
plus I will see if I have a wiring diagram on hand..
Dan
82 SuperCharged rx-7 {my toy not the daily driver anymore now under restoration}
88 B2200 rotary powered with a 7inch Camden SuperCharger !RIP! Jan/4/2007
2001 626 5-speed 80k on the clock all stock {Truck replacement}
2005 MAZDA6 V6 WAGON now that is a pimping ride all stock for the moment.. Paid off
WWW.AtkinsRotary.com
Atkins Dan is offline   Reply With Quote
Old 12-27-2008, 03:34 PM   #4
bwaits
Talk - Action = Nothing
bwaits is on a distinguished road
First things first is to see if you have power on the positive side of the coils when the key is on. Also check for voltage when the key is in the start position. This is overlooked quite a bit by people modifying the ignition wiring and end up find a 12 volt source but it cuts off when the key goes to start.
The amount of voltage you have will depend if the dizzy is still a points dizzy or if it has been swapped out for an electronic version. If you have a points dizzy then you should see a pair of white ceramic rectangular bars. They will have threaded studs on each end. 12 volts goes in one end and the other end goes to the coils. This is to cut the voltage down in order to not burn up the points.
Once you know you have voltage at the coils and have determined the style of distributor let us know.
Also, you should be able to find a wiring diagram at vintagerotaries. Here is a link: http://www.vintagerotaries.org/index.php?showtopic=38
-billy
bwaits is offline   Reply With Quote
